bluelair
- Joined
- Mar 17, 2018
- Messages
- 5
- Reaction score
- 0
Picked up a very clean looking Mark IIb on Facebook Marketplace. Previous owner said it was blowing fuses and he let it go for $200.
Serial is 6414, confirming the model. There is magic marker build date on the chassis saying 1981.
I talked with a local amp shop technician. He wouldn't take it in (said he doesn't work on Mesa because they're so compact) but he gave me some idea on where to start.
I have worked on Tube amps for about 10 years, but this is my first Mesa. I have assembled two Marshall 18w kits, built a Bottlehead Crack headphone tube amp and have modded many pedals.
First visual, things look clean. No burns, scorch, arc marks, no smell of burning around the components. Cabinet is clean and appears to be original 12" speaker. Also came with footswitch.
Fuses are 3A slow blow (per label on back of amp.)
The tech recommended I first pull all the tubes, replace the fuse and see if it blew again without the tubes in. Got some new fuses, pulled all the tubes, tried new fuse & power on. Fuse still blew with the tubes out of their sockets. ****.
The fuse blew instantly and I didn't notice any arc or spark in the chassis, just a mild flash from the fuse socket.
(Next, tubes still removed, unplugged, then discharged all of the capacitors with a 100k ohm/5W resistor for safety. Tested caps with a meter to verify no residual voltage.)
Mesa recommended to next test the silicon diodes, I found five on the power board where the large caps are. Tested each with a multimeter with a Diode test setting, results:
Diode#/Forward bias reading/Reverse bias reading
1/.531v/OL 2/.535v/OL 3/.536v/OL 4/.535v/OL 5/.546v/OL
So does all appear to be in order with those? This seems to be telling me the diodes are "good".
Are there any other visual inspections to perform before continuing with instrumented tests?
What would be the next thing to check? I've been told to check the power and filter caps, check the tube sockets for shorts, and that the PT might be bad.
