Electrolytic Caps
lions
I know about the big caps, but what do the smaller electrolytics do on a Mark amp? I've got replacements for the big caps on my Mark III but not these, what effect would replacing them have on the sound? I've heard before and afters with the big ones and it was a noticeable change.
The smaller electrolytics are mostly in parallel to the cathode resistors on the preamp stages. They increase gain. Unless they are faulty you will probably not notice much of a difference between one electrolytic and another.
Cheers Stephan
Those ones you have circled are for the various low voltage supplies. They are filter caps for bias, eq supply and vactrol voltage supply...
I think there are 2 in the bias supply (50u/75v?) that you should replace as long as you're replacing the filter caps.
Should as in, they need replacing with the filters? I've sent my amp off for the III+ mod & big filter cap replacement now so it's a bit late for that now. :lol:
