It is currently Wed Jan 17, 2018 5:05 pm
PostPosted: Tue Jan 02, 2018 4:56 pm
I would like to ad some more gain to my Purple Stripe Mark iii as well as get the R2 mod.
What mods could I have my amp guy do that would add a little more gain and possibly improve an already awesome tone?
I searched for a topic and couldn't find anything specific for the Purple Stripes. So, I thought I'd ask. If there is one please feel free to post a link.
JP-2C
1985 Mark iii Simul Class Black Dot/Red Stripe
1987 Mark iii Coliseum Purple Stripe
Mark IVb
Mark V
PostPosted: Sat Jan 06, 2018 2:27 pm
The R2 mod will let you dial in a better rhythm tone mix and to crank the input more to get more grit. A useful mod.
I use an MXR Microamp to boost R2. Goes from warm to blazing. Best solder free mod is a nice clean boost.
My Purple Stripe also has a mod to increase the reverb depth and to cure a slight noise that the purple stripes can have when using reverb. Mesa sent me a sheet of mods when I asked.
PostPosted: Mon Jan 08, 2018 9:21 am
In an earlier thread I described what I did to my 60 watt purple stripe Mk III. These changes were:
- replaced the 0.01uf cap in the feedback section that is parallel to the 56k resistor with a 0.005uf
- replaced the 0.002uf plate bypass cap on V3b (the second lead gain stage) with a 0.001uf
- fixed the reverb glitch (that is what is also mentioned in the post above)
- replaced V4 (the reverb tube) with a 12AT7
- replaced the speaker with an Eminence Legend MOD (preferred it over both the C-90 and the EVM).
Other than that I replaced the electrolytic caps in the power supply but since I used the same values as stock that is not a mod but maintenance.
Cheers Stephan
PostPosted: Mon Jan 08, 2018 4:05 pm
Thank you both for your replies.
darkbluemurder
I actually copied yours onto a Word Doc and am handing it to the Tech. thank you so much for all of that info!
Promethean
Thank you as well. I actually asked Mesa for a Mod sheet and they said no...lol
Sucks to be me sometimes.
Well, I am about to head out to the Tech's Shop. Thank you for your help!
JP-2C
Mark IVb
Mark V
PostPosted: Tue Jan 09, 2018 7:45 am
The reverb glitch fix is a 120k resistor from the red wire of the reverb transformer to ground. I have no idea why this works but it does.
The reverb increase mod is a 3.3k resistor that is inserted. Most of the posts I have read say it should be attached to the return jack connection but I have seen one drawing where it was attached to the send jack. You could also decrease the 1.5 meg resistor going into the reverb with a 470k (that is in the Mark IV or in the Lonestar - the Lonestar has a 250pf cap with a switch in parallel to the 470k - this is the warm/bright reverb switch). Going from a 1.5 meg to a 470k would drive the reverb harder. I can only guess that Mesa received wishes to make the reverb more Fendery so that's where the reverb evolved in later models.
I considered the reverb increase mod but dropped it since I am no big reverb guy anyway (personal preference). A little reverb for ambience is all I need, and the stock Mark III circuit provides that.
Cheers Stephan
