It is currently Tue Jul 17, 2018 4:46 am
PostPosted: Thu Dec 21, 2017 11:48 am
Greetings! I recently purchased a no-stripe Mark III, and in preparation for shipping the seller informed me that the index pins (the plastic "pins" or guide keys in the center of all four 6L6 power tubes used to align the tube to the socket) are all broken. While I understand that the tubes will operate perfectly well, and the seller assures me that the tubes were handled properly, it seems odd that all four pins would be broken. The amp otherwise appears in great condition. Any thoughts?
Thanks,
Mike.
PostPosted: Fri Dec 22, 2017 11:18 am
To be on the safe side, I'd just buy new power tubes when the amp comes & use those.
1991 Mark IV A
PostPosted: Sun Dec 24, 2017 3:01 pm
+1. It is almost impossible to correctly insert tubes with a broken alignment pin, and if you do you could be in for disaster. I know because it happened to me one time - the guide pin broke while inserting the tube and I did not notice it until I had sparks flying when flipping the standby switch. Had to replace the tube socket afterwards, and that is not work that I like.
Merry Christmas to all,
Stephan
PostPosted: Fri Dec 29, 2017 5:32 pm
Look for one of these:
https://www.tubesandmore.com/products/keyway-replacement-piece-octal-tubes
PostPosted: Sat Feb 03, 2018 1:45 pm
Ya, I agree with the above poster who said just buy new Power Tubes. It's better to do that anyway when you get a used amp. Unless they are already new. Just start fresh and right and eliminate any possible questions about performance. New Tubes all the way around position you to troubleshoot a lot more efficiently.
JP-2C
1985 Mark iii Simul Class Black Dot w/Red Stripe upgrade
1987 Mark iii Coliseum Purple Stripe
1987 Red Stripe Combo
Mark IVb
Rocket 4Forty
JP2C (#2)
PostPosted: Sun Feb 04, 2018 8:09 pm
DM47 wrote:
These work great!
