It is currently Thu Oct 18, 2018 5:00 pm
Post new topic Reply to topic  [ 14 posts ]
 Post subject: MKIIC+ Export
PostPosted: Sun Aug 27, 2017 11:03 pm
Greetings,....been a while since i have been here. Blessings to all. I have a question, how do I know if my 1984 MKIIC+ is an export series? My schematics are confusing me. Hope to here from some one. Sincerely, James.
MKIIC+
2:90
4x12 Recto Cab w/ Eminence and V30's
Home made 2x12 half open cab w/ Eminence and V30's
Rocktron Patchmate, Rocktron Intellifex, TS10 Tubescreamer
 Post subject: Re: MKIIC+ Export
PostPosted: Mon Aug 28, 2017 5:01 am
220-110 volt switch on the back panel of the amplifier chassis
2006 Fender Lite Ash Strat
2012 US Gibson Firebird V
1990 Boogie Mark 1 Reissue
2-12 Sapele Cab
Music: from blues to thrash and back! (allman bros, exodus, saxon, tcf, robert johnson)
PostPosted: Thu Aug 31, 2017 7:20 pm
Location: Looking over the shoulder of the guy who lost his apples - not that he really ever had any to lose.
Check to see if it has the X101 Output Transformer
PostPosted: Thu Aug 31, 2017 10:25 pm
Thanx for the replies... There is no voltage switch and where wud that number be located? Thanx for ur time, James.
MKIIC+
2:90
PostPosted: Wed Sep 06, 2017 8:12 am
It should be on the cover of the power transformer, if you have a head it's probably a little difficult to spot, maybe a mirror would do it. But for yours sake, look for a 100 or a 105 digit instead since there is no voltage selector. If yours is a 60, look for a 60 (ish).
http://tonykareid.com
Mark IIC+ SGX, DRGX x2
Mark III black dot DRGX
Mark IV A DRGX
Mark V:25
Dual Rectifier Rev G, Recto preamp
Cabclone
Mesa amp switcher
4x12 Recto standard
1x12 Thiele cab.
Tons of Ibbies, what a habit.
PostPosted: Wed Sep 13, 2017 11:25 pm
Tony am I missing something in your reply?
Pretty sure the PT has nothing to do with it being an export or not, it's the OT.
You should know as you own a couple. ;-)
Not sure what OT was used on the 60 watt C+ export but there again you own one so you should know.
PostPosted: Thu Sep 14, 2017 6:31 am
It's the other way around George. The PT(power transformer) is the one that's different. The OT is identical in the domestic/export, obviously different in the 100 and simul and 60. My PT's are X101 on both simul IIC+'s and my black dot Mark III. The 60w C+ has the X62.
Mark IV A DRGX
Mark V:25
Cabclone
Mesa amp switcher
4x12 Recto standard
1x12 Thiele cab.
PostPosted: Thu Sep 14, 2017 9:34 am
DOH!! You're correct!! :shock: :oops: I must have had a "brain f*rt" ! :oops: What was I thinking??!!
PostPosted: Thu Sep 14, 2017 10:46 pm
Thanx for the replies. I'm confused now. If my MKIIC+ (Simual) doesn't have a voltage knob, it cud still be an export based on the transformer? Thanx, James
MKIIC+
2:90
PostPosted: Fri Sep 15, 2017 4:20 am
If it doesn't have the red voltage selector it won't be an export model.An export model is one that has a different power transformer able to select the required voltage depending where in the world you are ie US/UK/EU etc.
PostPosted: Fri Sep 15, 2017 7:23 am
It is possible that the amp could have the X101 Power transfomer hard wired to the 120V taps, and have no voltage selector switch. I think that I saw one for sale on Ebay done this way.
"One of these days, I'm gonna change my evil ways....... one of these days.
PostPosted: Sat Sep 16, 2017 3:30 am
Yes, I've seen and owned MkIIs of varying generations that have been hard-wired after the fact, though here it's generally easier to find export transformer Boogies with the normal selectable voltage (red knob) than specifically 200, 220, 230 or 240V models. Some of the EU hard-wired ones even look factory.... I may ask John Kelly (Rocky Road's Mesa tech of choice) about this next time I take an amp to him for work.
Mesa also don't mention, however, that some US market models - like my Coli IIB - actually came with a transformer tapped for EU voltages, but only wired to the back panel for 110V.
MkII eh?
PostPosted: Mon Sep 18, 2017 5:20 am
I was actually gonna say that that might be possible but wasn't 100% sure if they ever did use an export transformer hardwired for the relevant voltage.
PostPosted: Wed Sep 20, 2017 6:45 pm
I had a 60/100 that had the X101 PT, no voltage selector switch.
Used it for years and suspect it was hard wired to the 120V taps as I'm in the good 'ole usa.
I've actually seen a few over the years with the X101 PT that had no voltage selector switch.
