MKIVB Versions: Detachable Power Chord
Wizard of Ozz
Post by Wizard of Ozz » Fri Aug 04, 2017 2:48 am
Anyone know when Mesa switched the MKIVB to the detachable power chord? I'm pretty sure it was sometime in late 1996 or early 1997. Anyone know when for certain? Thanks.
igfraso
Re: MKIVB Versions: Detachable Power Chord
Post by igfraso » Fri Aug 04, 2017 10:40 am
Not for certain but just for info... the transition between the MkIV-A and the early B version (or noA/noB) seems to have happened around the lower s/n 5800's.
In the forum, there is someone with an early B s/n 585X (Dec 92? or Jan 93?) and another one with a full B s/n 689X (Dec 93).
Daniel
Wizard of Ozz
Post by Wizard of Ozz » Fri Aug 04, 2017 12:50 pm
igfraso wrote:Not for certain but just for info... the transition between the MkIV-A and the early B version (or noA/noB) seems to have happened around the lower s/n 5800's.
Thanks. But I am wanting to know when the MKIVB version switched to the detachable power chord. I've seen some 1996 models with it still attached, so I wanted to know when it changed. Thanks.
igfraso
Post by igfraso » Sun Aug 06, 2017 1:59 pm
I thought that all full B had a detachable cord so I would have said from Dec 93 on. But you have seen newer amps with the cord still attached.
Daniel
