New Amp! Hardwood Simul-Class Purple Stripe Mark III Combo
s-fresh
Post by s-fresh » Mon Oct 03, 2016 11:37 pm
Well I can't seem to hang on to any gear lately, once I get something figured out I decide to move on to something else. Hopefully this amp ends up sticking around. I haven't even got to play it yet, my little guys are sleeping now. Will give it a go tomorrow afternoon when I get home.
It's a DRG with EVM-12. Overall it seems to be in great shape for an '86. I'm stoked to join the Mark III club. I've had a II, IV, V and V:25 so far and haven't found exactly what I was looking for. Hopefully this is it! Considering making a consolidated pedal with crunch/lead/eq/reverb switches but need to decide if this one is a keeper first.
One question I did have, this came with four 6L6/STR420 power tubes. Being it is simul-class should I switch that outer pair to EL34s? I've read on some posts that certain 6L6s are okay in simul-class outers but others are not. Are Mesa STR-420s a safe one or should I not even try? I am mostly interested in the low-watt settings for now. That's why the purple stripe was particularly interesting to me. The manual does clearly say EL34 but I thought for some reason that was old information.
Here it is after a quick cleanup:
s-fresh
Re: New Amp! Hardwood Simul-Class Purple Stripe Mark III Com
Post by s-fresh » Tue Oct 04, 2016 8:15 pm
So far so good. I was able to get a lot of sounds I liked out of it, now for the slow process of setting it up so all three modes sound good together with shared settings.
The reverb is really weak. I will remove and see if it is damaged or just dirty soon.
Promethean
Post by Promethean » Wed Oct 05, 2016 12:24 am
That's a beauty!
I have a purple stripe too and love it. Been gigging it for 30 years now.
Has it had the R2 level mod? That lets you dial in the mix of R1 $ R2. There is also a very simple mod to add more to the reverb depth to the MK3.
A clean boost (I use an MXR microamp) adds loads more options to goose R1 & R2. Boosted R2 is particularly nice. Very Marshall like.
I use mine currently with Mesa matched Svetlana =C= 6L6s which are great but I have used the mix of Mesa EL34 in outer pair and 6L6 in middle for lots of years. Slightly tighter bottom end with EL34s in 15w mode.
Elpelotero
Road King
Post by Elpelotero » Wed Oct 05, 2016 4:06 am
I have used my Simul with 420's at times. Nothing bad happens, it works and sounds good. However, it is not a rugged tube, and wears out quickly. Since there are not that many of them out there, I'd switch it to something else for the outer sockets, another 6l6 or el34.
'92 Dual Recto Rev. D, Volume mod
'84 Mark IIC+ Coliseum
'85 Mark IIC++ DRG, V1 mod
Mesa Standard 4x12
1980's EV Thiele
Sold:
'92 Dual Recto Rev. C
'92 Dual Recto Rev. E
'05 Dual Recto 3ch
'84 Mark IIC+ DR
http://www.TheBoogieArchives.com
kdorsey
Post by kdorsey » Wed Oct 05, 2016 7:06 am
If nothing else, you should at least try the EL34s. You've got a Simul-Class amp and need to understand what makes it so unique. Especially, explore class A mode with EL34s. I'd also recommend using different cabs with different speakers because, IMO, the EV limits the potential of this amp.
'89 Mk III Combo - green stripe
Simul w/ EL-34s | EQ | Rev | EV12L
(2) Boogie 2x12 Half-back Cabs
igfraso
Post by igfraso » Wed Oct 05, 2016 9:52 am
Marks III and IV were designed for STR 420 tubes so you are absolutely safe with them. Of course, try the EL34 as well.
One piece of advice: do the R2 Volume mod and the Reverb mod (I think the latter came from factory from Blue stripes on).
Daniel
s-fresh
Post by s-fresh » Wed Oct 05, 2016 11:33 am
Thanks for all the replies!
I'm pretty sure this thing is 100% stock. Are all these mods at the level of a competent solderer or are these something only Mesa can do? I am in Northern California and my sister lives near Petaluma so I could probably drop it there at some point. Would rather do it myself if it isn't anything crazy.
Looks like I need to order some EL34s and try them out!
BoogieHog
Post by BoogieHog » Wed Oct 05, 2016 2:07 pm
Man that is a beauty! I got a Black Dot with a Red Stripe upgrade a few weeks ago that looks just like that. I'd keep that beauty for good!
JP-2C
1985 Mark iii Simul Class Black Dot w/Red Stripe upgrade
1987 Mark iii Coliseum Purple Stripe
1987 Red Stripe Combo
Mark IVb
Rocket 4Forty
JP2C (#2)
igfraso
Post by igfraso » Wed Oct 05, 2016 4:56 pm
s-fresh:
if you are living relatively close to Petaluma, bring it to Mike Bendinelli. He will go through it (it is a 30-year old amp) and will do an in-depth cleaning and check capacitors, etc. The mods are cheap and he will do them as well for you. You won't regret it.
Daniel
Promethean
Post by Promethean » Thu Oct 06, 2016 1:09 am
I live in the UK and Mike B sent me the notes for the mods so I could do them myself. If you are close to them on California I am +1 dropping it in to them. Just not an option for me. None are hard to do and the main thing, if you are competent and soldering and using a meter, is to be secure with the safety rules around amps and charged caps, etc.
I've done:
'R2 Level Mod'. This adds a control (mine is dual gang pot in the direct level spot) that sets the R1/2 mix. It's pretty much set and forget. It's just a pot replacing one readily accessible resistor on the PCB. Documented well here. Transforms a MK3's versatility.
'Reverb Depth Mod' - this is a super easy mod that just puts a resistor in line with a lead from the PCB that terminates on the fx loop earth tab. I put a larger value than recommended in to get to Dick Dale levels if I want. It's got it all now from subtle to fender like.
'Reverb Glitch Mod' - this might be needed on your Purple Stripe. The symptom is a very low level of background noise/distortion when the reverb is used. An extra earth connection from a reverb transformer cable to earth (used the nearby reverb phono sockets earth tab) solves it perfectly. Mine is now completely noiseless.
There are suggestions in their notes for other value changes for a couple of components that I did not do.
I also put an in-line switch on the fan cables to silence it for recording. I might just try a new super silent fan soon.
With its age I will be ordering a new set of main Filter Caps to swap in the next few weeks. Probably worth getting done if recommended. I am just starting to hear a strange compression and garbled attack on clean notes hit hard.
I think the Mark 3 has some magic that I've not found with Mk5s or other mesa models. More 'alive'.
BoogieHog
Post by BoogieHog » Thu Oct 06, 2016 12:08 pm
Promethean wrote:I live in the UK and Mike B sent me the notes for the mods so I could do them myself. If you are close to them on California I am +1 dropping it in to them. Just not an option for me. None are hard to do and the main thing, if you are competent and soldering and using a meter, is to be secure with the safety rules around amps and charged caps, etc.
I've done:
I agree with every bit of that especially that last quote!
JP-2C
Mark IVb
Rocket 4Forty
JP2C (#2)
Wyzard
Post by Wyzard » Thu Oct 06, 2016 3:09 pm
My favourite MkIII blue stripe runs a close-ish second behind my IIC+s. "Alive" would be a good description, but the MkIIIs are several degrees harder to drag kicking and screaming to tonal dead-centre on any given night than the C+s.
So they are what they are; but I confess - I love the fight.
MkII eh?
s-fresh
Post by s-fresh » Sat Feb 18, 2017 12:58 am
Well instead of doing on these mods I went out and found another amp that has all these changes already made. Its a Simul-class Mark III red stripe head with GEQ and reverb. "III+" upgrade, reverb fix, R2 volume mod, and a pentode/triode switch. It also came with fresh Winged "C" EL34s and 6L6s power tubes. I just got it all unpacked and am looking forward to tomorrow morning when everyone wakes up so I can take it for a spin. I've been buying/selling a lot of Mesa stuff and this is probably my best find so far. It looks like someone wanted to do pretty much everything to their Mark III. Stoked!
Thanks for all the responses, everyone!
MkIII Renegade
Post by MkIII Renegade » Sun Feb 19, 2017 6:26 pm
s-fresh wrote:Well instead of doing on these mods I went out and found another amp that has all these changes already made. Its a Simul-class Mark III red stripe head with GEQ and reverb. "III+" upgrade, reverb fix, R2 volume mod, and a pentode/triode switch. It also came with fresh Winged "C" EL34s and 6L6s power tubes. I just got it all unpacked and am looking forward to tomorrow morning when everyone wakes up so I can take it for a spin. I've been buying/selling a lot of Mesa stuff and this is probably my best find so far. It looks like someone wanted to do pretty much everything to their Mark III. Stoked!
I hope the new one (replacement?) still has the hardwood/wicker cab. That is a true beauty!
I had my III upgraded with R1, R2Vol and Reverb mods, and it my favorite amp of all! The Lead channel especially is to die for.
Quad Preamp/2:90
MkIII+ Simul-Class & MkIVb
Mark 4x12 Stack
Charvel 650 Custom/EMG85/SLV/SLV+SPC
Charvel San Dimas I Koa USA
Jackson Soloist Pro MIJ
B.C. Rich Eagle Evo2/Air Norton
ESP Eclipse EMG 81/60
Ibanez UV7BK
Charvel 475 Exotic
Fender Tele USA
MkIII Renegade
Post by MkIII Renegade » Sun Feb 19, 2017 6:29 pm
Promethean wrote: I think the Mark 3 has some magic that I've not found with Mk5s or other mesa models. More 'alive'.
I agree! I have not played the fabled Mk IIC+, but I have played several other Mesas and have a MkIV. The MkIII has my favorite Lead channel, hands down. 8)
Quad Preamp/2:90
Mark 4x12 Stack
Ibanez UV7BK
Charvel 475 Exotic
Fender Tele USA
