Speaker cab questions for the Mark V 25 head
Noodleboy
Okay y'all I just bought a brand new Mark V 25 head and I own two Boogie cabs.
The first cab is a Thiele 1x12 with a single 8 ohms input jack.
The second is an open backed 1x10 with a 8 ohms input jack and a "paralleled out" jack that has a cap on it at present.
I've run both of these cabs alone in the 8 ohm position on the amp.
My question is can I run them in tandem?
If I can, which out should I use on from the amp?
Lastly, I assume I would go from the amp (8 or 4 ohms) to the 1x10 and then using that "paralleled out" jack, cable out to the 1x12.
Sorry for the dumb question but I don't want to screw anything up and would really like to run both cabs at once.
Thanks.
