TheHypnotoad
hi guys,
I've a looper\switcher that I want to operate with my lovely Mark 25, the switcher had 2 jacks TS for channel changing, working with the tip to the ground sistem.
the jack in in the Mark is a TRS and in the manual, as far as I know, there is no information on the method used to change channel or engaging Eq.
so, the question is: if I use a 'Y' cable (two TS in a TRS) It's possible to switch proprely without any trouble\harm on the amp?
thankss!!
A.
thankss!!
A.
