Hi folks.
I've read of the problems associated with the effects loop in the 2B and the effects loop Mod but I thought the issues were only with the Reverb equipped amps and the lead channel?
My 2B,Non Reverb/Eq sounds terrible with my delay pedal through the loop.The delay repeats are distorted with a noisy mushy sound.This is on the clean channel.Plug the delay into the front end of the amp and it sounds fine but then I can't use the lead channel and that's one of my favourite things about the Boogie is the preamp overdrive!
I love my delays and almost always have one on.Delay is a Boss DD3.
Is this description typical of the loop "problem" or is something else going on here?
Any help would be much appreciated.
I'm not having much luck with this amp at all.
