Warm up time for a Mark amp?
BlackBoxy
Re: Warm up time for a Mark amp?
Post by BlackBoxy » Thu May 28, 2015 10:59 am
to play , 2mns of heaters on tube are enough to safely use the tubes !
but, to make it singing, a warmed caps and power supply (current stabilized) is better, so 20- 30mns of warm up is required
megavoice
Post by megavoice » Fri May 29, 2015 12:17 pm
Yes, 2 or 3 mins in the Standby mode are enough but 2 or 3 hours or more in "Power On" mode for an extraordinary sound...........
It had been mentioned here for several times..........
Gear List:
'85 Gibson Les Paul Black Beauty All Gold
'01 Gibson Art & Historic LP Standard
2 Combo-cabs, redstripes fully loaded, tolex, EVM speaker
1 imbuya hardwood cab, EVM speaker
2 thiele cabs, EVM
MkIII Renegade
Post by MkIII Renegade » Fri Aug 14, 2015 7:37 pm
I give my tube amps 2-3 minutes on standby before playing at mild volume. My MkIV in particular seems gutted unless it's been played for 15+ minutes. I never noticed before having the MkIV that the MkIII also improves after warming up, but it doesn't take as long to reach nirvana.
Quad Preamp/2:90
MkIII+ Simul-Class & MkIVb
Mark 4x12 Stack
Charvel San Dimas I Koa USA
Jackson Soloist Pro MIJ
ESP Eclipse EMG 81/60
Ibanez UV7BK
Charvel 475 Exotic
Fender Tele USA
MrMarkIII
Post by MrMarkIII » Fri Aug 14, 2015 11:10 pm
Mesa says 30 second warmup, but what would they know, they only designed the durn things.
As for hanging upside down, etc., the first Boogies were modded Princetons, which, surprise!!! have hanging tubes. It wasn't broke, and they didn't fix it. Once they got into the "real" amp head business, like Peavey, Soldano and everyone else, they copied Marshall.
Oh, dear, I'm boring myself...
I once played a lot of one-nighters, where the trusty ol' Mark III sat in its road case in the cold, cold garage, then back of the cold, cold truck en route.
(And this is SoCal. I can't imagine Minnesota. Yikes!)
Once flipped on, it seemed to take a good hour or so to warm up and not sound brittle. It got to where I'd just leave it "on" for the entire gig after warm-up, because I thought it sounded better. Works for me, YMMV.
BlackBoxy
Post by BlackBoxy » Wed Aug 19, 2015 3:03 am
Mesa copying Marshall?
i found both schematics structures rather differents
Tube guitar amps builder doesn't need to copy anyone , as the technology is simple !
this guy build great amps , and trying to get Marshally tones , without copying
http://www.fxamps.com/
a tube amp power supply need 20mns at least to be fully stabilized (current and heat) waiting 4 days or 100 mores will not add any heat or stibilized current!
