Mark IIB at the Tech for a Checkup
DC3 Gridlock
Tampa Bay, Florida USA
Bought this amp a few months ago and love it.
Checking filter caps, tubes, and swapping out the two outer EL34's (Simul-Class model) with two 6L6's.
Hoping this smooths out the overdrive tone a bit and I just prefer the tone of 6L6's over EL34's.
Any other items that I should ask the tech to check out?
Thanks,
Grid
You may want to double check else where here on the Board but I did read that Simul Class has a higher tube failure with four 6L6's in it, versus the two EL-34s on the outer sockets.
I've read the same but I contacted Mesa and they stated no issues. Probably need to stay with Mesa branded tubes.
Thanks,
Grid
If it has the original filters,a re-cap will be necessary.If you want to "smooth" out the distortion,a NOS 5751 in V1 and/or V3 will go a long way to that end.If you have the money NOS 6L6's are nice too.When using 4 6L6's one pair will be very cold,the bias supply can be tweaked to get them closer.A general cleaning will be all else thats needed,should include socket re-tension.If the switching works,I wouldnt be too concerned,all he's going to do is try them,if they work,they are good.
Thanks great advice. I will definitely look into changing V1 abd V3.
Got my amp back from the tech that took well over a month to do the job but I amp pretty happy with the work.
Changed out the two outer EL34's (Simul Class) and the inner 6L6's with a new quad of Mesa branded 6L6's, filter cap changes, a few preamp tubes, a general checkup, and a new blue indicator lamp.
Sounds great with the quad of 6L6's, the clean is even better and the overdrive seems smoother though I have not really had a chance to ring out the amp since bringing it home.
The reverb is even more pronounced.
