Mark III footswitch help
mboogman
Can anybody help me out with how the EQ/REV FOOTSWITCH is wired. After experimenting, I'm pretty sure it's not just a simple TRS to 2 switches kind of thing. I've had two MK IIIs, and they both have done the same thing. Wired like a normal switch, both switches have to be off to completely turn off both the reverb and EQ circuits. I'm guessing there would be a resistor or some diodes in there somewhere?
dodger916 said:
Can you open it up and look?
If I had one of the switches to look at, then yes. I Don't have one, which is why I asked. Hoping that someone around here has one or knows how they're wired. I'm working on a custom switching solution.
Well now that we have that cleared up, my Mark II Eq/Rev footswitch has two switches and no resistors or diodes. Pretty much "...just a simple TRS to 2 switches kind of thing".
Hope that helps. This might help too: http://forum.grailtone.com/viewtopic.php?f=3&t=10819&start=15
And if that's not enough how about this, picture too: http://forum.grailtone.com/viewtopic.php?f=27&t=36627&hilit=reverb+footswitch
