Mk-IV Volume knob is very touchy
ChuckCastiglione
Post by ChuckCastiglione » Sun Aug 31, 2014 10:00 pm
The main volume knob on my Mk-IV is extremely touchy. It is hard to keep the volume low. I usually have the master at 1-1/2 because if I go any higher the amp gets extremely load. I've changed the volume pot and it didn't make any difference. I've been using my channel masters to control the overall volume but I noticed that my effects were being over-driven with the individuals turned up to 5 or 6. Please let my know what you think?
Chuck
themisfit138
Re: Mk-IV Volume knob is very touchy
Post by themisfit138 » Sun Aug 31, 2014 10:59 pm
Sounds about right. That how mine acts also. I just assumed that how the Mark IVs were.
1985 Mark IIC++
1989 Mark III Blue Combo
1991 Mark IV Short Head
HBob
Post by HBob » Mon Sep 01, 2014 8:38 am
Sounds like mine. You can turn the channel masters down to 2 or 3 and it will make the main output knob less touchy. I like the channel masters run around 5 or so (makes the amp sound more raw, less smooth to my ears - I think you're hitting the output tubes harder when you turn up the channel masters) but if that's overdriving effects in the loop you should turn them down. I sometimes run a rack reverb in the loop and it has individual input and output level controls so I can even things out and not overdrive the effects unit.
zebpedersen
Post by zebpedersen » Mon Sep 01, 2014 10:39 am
It's a feature, not a bug :)
I learned on my Subway Rocket way back when to turn the volume pot very carefully by kind of 'smudging' my thumb to get it *just right*. Anything below 1.1 was manageable, anything above 1.1 was firmly in the NSFN (not safe for neighbours) category. It's a bit like the biting point of a clutch.
Same deal with the various Marks I've had since (including a IV-B). Try pushing your thumb down with half the pad on the skirt of the pot and half on the chassis and turning very slowly.
Mark I HRGX 15"
Mark IIC+ DRG
SonVolt
Post by SonVolt » Tue Sep 02, 2014 7:07 pm
Same with mine. I have to lightly tap the volume knob hoping it turns a hair.
ChuckCastiglione
Post by ChuckCastiglione » Tue Sep 02, 2014 8:02 pm
Anyone know if there is a remedy to make it work a little better?
SonVolt
Post by SonVolt » Tue Sep 02, 2014 9:56 pm
Turn the channel master down.
UglyBunny
Post by UglyBunny » Sun Sep 21, 2014 8:37 pm
You guys crack me up - mine does the same thing and you're all describing how I have to finesse the master volume :)
And yep - 1.5 sounds about right even for church practice volume. It's a loud little bugger :)
eatsleeprock
Post by eatsleeprock » Sun Sep 21, 2014 9:12 pm
In jam (we are admittedly a fairly loud five piece) I run my master volume on the high side of almost three. In the lower regions, for less aggressive playing, I also find the knon very sensitive. You're running a 85 watt amp, it's the nature of the beast. Turn down the channel masters a bit, run it in tweed, triode, and class a modes. That'll lower the overall output. Won't make the knob any less jumpy, but it will make the beast slightly easier to wrangle. If it's really bothering you, but a volume pedal in the fx loop and dial it down.
Or buy a mark v mini. ;)
Triaxis - 2:90 - T.C. Gsystem - Line 6 G55
Half back Metal Grille Mesa 4*12
Marshall 1936 2*12 w/ v30's
2x Mesa spec 1*12 w/ v30
Orange TH30
Gibson Custom Lite w/ JS Moore buckers
Gibson wine red Robot Les Paul
'78 Aria Pro II
dodger916
Post by dodger916 » Sat Sep 27, 2014 8:08 am
I'm pretty sure you can replace the volume pot with a less touchy taper.
1966 Fender Pro Reverb
DC-3 head
Orange Dual Terror
CyrilW
Post by CyrilW » Tue Oct 07, 2014 4:17 pm
What about an audio taper pot? Has anybody tried that? I was going to see if Mesa would install one when I send my Mk IV in for service.
1993 hardwood Mark IV short combo, 1990 Simul-Satellite, 1x12 hardwood Thiele cabinet
yelly
Post by yelly » Sat Nov 29, 2014 1:26 pm
My mark iii was the same until the volume pot was renovated. Spraying deoxit might help if your are lucky. I removed the whole pot: dissembled, cleaned and retensioned the wiper. A really awkward job to get the pot in/out. Depends how much it bothers you.
