List of filter capacitors needed for a Mark III cap job
jofipe
Post by jofipe » Wed Feb 19, 2014 2:52 am
Hi there. I'm gonna send my amp to the tech, but he doesn't use F&T caps (JJ only), so i'm gonna just order them online myself.
So far what i'v gathered I need:
The main filters are 4X220uf/300V. The preamp decoupling caps are 3X30uf/500V.
Anything else?
stokes
Re: List of filter capacitors needed for a Mark III cap job
Post by stokes » Wed Feb 19, 2014 11:08 pm
2X220uf/63v for the EQ supply and 2X80uf/75v for the bias supply.
jofipe
Post by jofipe » Mon Feb 24, 2014 3:40 pm
Tank you very much stokes! I take it that these ones have a rather minor effect on the overall tone?
stokes
Post by stokes » Mon Feb 24, 2014 5:42 pm
jofipe wrote:Tank you very much stokes! I take it that these ones have a rather minor effect on the overall tone?
Yes,but they are electros and are just as old as the power filters,cost is minimal compared to the filters so while you're in there......If you cant find exact values,close is good enough for these,as long as the voltage is the same or higher.Be careful tho,physical size can be an issue,theres not a lot of room where these are located.
jofipe
Post by jofipe » Mon Feb 24, 2014 9:03 pm
Awesome info :) ill go get some filters to tomorrow
Paul Johnson
Post by Paul Johnson » Fri Mar 03, 2017 6:43 pm
stokes wrote:2X220uf/63v for the EQ supply and 2X80uf/75v for the bias supply.
Where is the EQ Supply located...I can't locate the 2 caps...please help.
Cheers, Paul
GJgo
Post by GJgo » Mon Mar 06, 2017 11:36 pm
I can email you a copy of my receipt from when Mike B. did mine last year if you want.
