The Mark IV thread....!!
UsrName
Post by UsrName » Tue Oct 17, 2006 8:57 am
I've noticed that on some MKIVs, there are circular cut-outs on the top where the mounting screws usually are. My combo doesn't have these, just the normal screws and washers.
What are these holes for? They look like holes that would fit the rubber feet on the bottom of another amp.
Cheers!
PRS CE24
Vertical 2x12 Rec cab
Shep
Post by Shep » Wed Oct 18, 2006 9:25 am
in the day's when the combo was all mesa had.some people would stack 2 up,2 across to make a quad..the hole's made sure the amp''s held in place.so yes rubber feet holder's
Mesa Mk IV
Mesa MK IIc+ Simlu,Rev,Eq Cream with matching 1x12 EVM Cab
Mesa Mk IIc+ 60w, Rev, Export, combo EVM-12
Mesa EVM-12L 1x12 Theile Cab
Mesa trad 4x12 cab
mesa MK III blue stripe (sold)
Mesa dual recto 3 channel ( sold )
UsrName
Post by UsrName » Fri Oct 20, 2006 4:14 pm
I should be getting a used empty Thiele cab next week sometime. I'm going to put the EV in it, which should sound pretty damn good. Now, what speaker to put in the combo for a warmer sound?
The EV is pretty clean and uncolored, which I'm not used to, so I'd like to balance out the sound a little. I was thinking of a Neodymium to save on weight, but I don't want to possibly compromise tone. I also don't want one speaker to over power the other, so I'm trying to keep the db rating the same. Except for the Celestion Vintage, the Neos are pretty high in efficiency.
Any suggestions for a little coloring of the sound in the British tradition? I was thinking maybe a V30, or C90, or even a T75. I'd like something with good, tight bass and smooth highs. Not much experience with Eminence, though. I hear their neo Tonker sounds great. Anyone? Thanks.
Cheers!
PRS CE24
Soulcrusher_X
Post by Soulcrusher_X » Sun Oct 22, 2006 12:09 am
UsrName wrote:I should be getting a used empty Thiele cab next week sometime. I'm going to put the EV in it, which should sound pretty damn good. Now, what speaker to put in the combo for a warmer sound?
Hey man! I finally signed up over here. I should've done this a while ago after all the Mesas I've owned. The V30s sounds pretty good to me, but I think a few C90s might find their way into my 4x12. I also would like to try some Greenbacks or maybe G12-65s. I tried mixing two V30s and two CL80s, and it just didn't seem to cut it for me. Looks like I'll have to try something else.
JAMz
Post by JAMz » Tue Oct 24, 2006 10:47 am
UsrName wrote:I've noticed that on some MKIVs, there are circular cut-outs on the top where the mounting screws usually are. My combo doesn't have these, just the normal screws and washers.
I think you're reffering to the sus-4 system. This system provided a cushion for the electronic's chasis. In fact, the amp chasis was held to the wooden cabinet by a suspension system (sus-4) that consisted in a rubber insert held by two screws attached underneath the cabinet's top. That rubber insert has a metallic eyelet where the attaching hardware (screw & washer) is fixed. Clever design!. My MkIV and MkIIb have them. I beleve that the rotuing for a sus-4 is slightly different than a regular chasis. My 2 cents.
MkIIb Imbuya 1X12 EV12L w/ Matching ext. Cabinet
MkIII simul-Class Blue Stripe 1X12 EV12L
MkIV-A Short Chassis Head
MkV Head
Roadster 1X12 Cocoa Bronco
2X12 RK Cabinet
UsrName
Thiele cab arrival!
Post by UsrName » Thu Oct 26, 2006 9:52 am
Well, I got the Thiele cab in yesterday. I quickly swapped out the EV from the combo and put it into the cab. All I can say is WOW! It's hard to believe how much bass response comes out of this little box. At first, I thought "no way is this little thing gonna sound as huge as I've heard". Wrong! It's sounds just as good as my closed back 212 cab. In fact, my kid, who was upstairs, thought I was playing through my 212!
The EV sounds so much better in the Thiele than in the combo. The highs aren't as piercing as before, and the sound is much smoother now. Needless to say, I'm going to sell the 212 cab to fund a new speaker for the combo. Yeah, it's that good!
I stacked the combo on top and it makes a cool little stack. I'll snap some pics when I get a chance.
Cheers!
PRS CE24
UsrName
Does anyone know if I can run the 8 ohm cab with a 16 ohm speaker in the combo? I have a G12T-75 lying around that I want to throw in until I get a replacement.
Which speaker outs would I use? What would the sound difference be by hooking up a 16 ohm? Are there any adverse affects to my amp by doing this? Thanks.
Cheers!
PRS CE24
Russ
Mark IV Lover
Post by Russ » Tue Nov 07, 2006 3:13 am
While talking to Mesa, I was told that I could run my 16ohm 4x12 Marshall 1960ax cabinet loaded with Greenbacks in the 8ohm jack provided that I keep things reasonable volumewise. Apparently the tranny can take it so long as you aren't pushing things and the speakers won't go into meltdown provided you keep control of your volume. On the other hand, I like the sound of it in the 8ohm tap with my Thiele in the 4ohm jack. I hope that helps. In your case, you could use that 16ohm speaker into the 8ohm jack and keep your EV in the 4ohm jack.
Mismatching for less ohms than the speaker actually is makes for a slightly different sound coming from your speaker. It is not something that I would suggest doing for extended periods of time with any significant volume. I have yet to try the G12T-75 solo yet in the combo. I have a 1960a cab loaded with them but haven't experimented with them by themselves nor in an openback cabinet. Good Luck...
+1 on the sound of the EV in the Thiele
Soulcrusher_x- Greenbacks and 65's sound good with the Mark IV provided you are not looking for Death Metal. I have found some really smooth tones coming from the Mark IV creating buttery leads with those two speaker choices.
UsrName
Post by UsrName » Tue Nov 07, 2006 10:01 am
Thanks Russ. I threw the T75 in, but I didn't care for the sound. I'm probably going to go with an MC90 or a V30. Definitely something with less highs.
It seems everytime I turn the master up, the highs are really pronounced. I don't know if it's the amp or the speaker or what. I've tried turning down the presence, treble and the hi-freq eq sliders, but no luck. So I need to balance it out a little, while adding a bit of the old Celestion coloration.
Cheers!
PRS CE24
Barry
Post by Barry » Tue Nov 07, 2006 9:08 pm
[quote="UsrName"]Thanks Russ. I threw the T75 in, but I didn't care for the sound. I'm probably going to go with an MC90 or a V30. Definitely something with less highs.
It seems everytime I turn the master up, the highs are really pronounced. I don't know if it's the amp or the speaker or what. I've tried turning down the presence, treble and the hi-freq eq sliders, but no luck. So I need to balance it out a little, while adding a bit of the old Celestion coloration.[/quot
After all the your clammering i've got to have a Mark IV . I played through a Mark IIB for 21 years and then went to rectoverb and finally a Road King and Stiletto . I guess Ive gone full circel as im headed back to the Mark series .
Stiletto Deuce stage II
Lone Star head 10/50/100
Mark V Head
Mark II B Combo
4X12 Stiletto slant cab
2X12 Recto horizontal cab
1X12 Wide Body/Closed Back /front ported cab
UsrName
Post by UsrName » Wed Nov 08, 2006 1:49 am
Barry wrote:After all the your clammering i've got to have a Mark IV . I played through a Mark IIB for 21 years and then went to rectoverb and finally a Road King and Stiletto . I guess Ive gone full circel as im headed back to the Mark series .
I actually played the Stiletto, F-50, and Roadster 1x12 the other day. I really, really like the tone of the F-50(I even had the F-30 for awhile). I thought for a brief moment about selling the Mark IV and picking up the F-50 combo.
But after playing the Mark for 2 hours straight just now, I came to my senses and forgot all about the F-50! There are so many tones hiding in there is ridiculous! The grass is always greener, ya know.
Let us know when you re-join the Mark brotherhood.
Cheers!
PRS CE24
willrock
Post by willrock » Wed Nov 08, 2006 9:50 am
i'll tell you my story guys, i have a mark IV for over a year now and i've thought of selling it for a while, but before it, i tried the DR for almost a month and i dont like it at all with all the fizz and muddiness so i tried the triaxis, its still not good enough for me, to cut the story short, i was really really glad that i didnt sell my mark IV. nothing beats my MArk IV baby!!
soundclick.com/wiljam
UsrName
Post by UsrName » Wed Nov 08, 2006 11:16 am
Anyone use a pedal to get a "Recto" sound? Although, I'm lovin' my MKIV, I also like the voicing of the rectifiers. I really like the tone Adam Jones of Tool gets and also A Perfect Circle. Not the highest gain, but the voicing is there.
I'm thinking maybe a V-twin? A lot of people complain that there isn't enough gain, but that's ok with me, I just want the Recto voicing. Does this pedal have it? Any others to consider?
And before anyone says: "Just buy a DR", I don't have the cash for another amp, nor would I want to lug 2 amps around anyway. So, I'm just looking for a pedal such as the V-twin that will give me that sound. Thanks fellow boogiers!
Cheers!
PRS CE24
postmanpat
Post by postmanpat » Fri Nov 10, 2006 12:43 am
hey guys!
i'm glad i found this forum, it has such a brilliant wealth of knowledge and experiences,
i'm currently saving for a new amp for rehearsing, and giging (anything from parties, to 100-200 venues, to church on sundays,
and up until yesterday i was thinking about either the lonestar 2x12 or a roadster 2x12, but now my friends i'm starting to like the idea of a mark iv as a head with a thd 2x12 cab,
i've heard some wonderful solo's from the mark iv, but not alot of rhythem or clean strumming work,
i play anything from foo fighters, to smashing pumpkins, dream theater, satch, classical finger picking, the darkness and the odd rolling stones,
my main question is will the mark iv fit my needs for those styles, i very much like the idea of finding a great clean, and rhythem setting and rolling of the guitar volume according to the type of song,
and also having a smaller head i could get a 1x12, 2x12 or dare i say it 4x12 for out door gigs!
Shep
Post by Shep » Fri Nov 10, 2006 1:02 am
yes it will...with a 2x12 recto cab that would be killer..
Mesa Mk IV
Mesa trad 4x12 cab
