mark 3 coli, simul, eq, running all 6L6 tubes
played the other day for about 30 minutes and shut amp off. Turned back on about 5 minutes later but did not use standby switch (thought amp would still be warm). amp made a funny humming noise, so turned standby switch on and let it warm up for a few minutes. turned standby switch off and guitar had very little volume and increasing hum from amp, then something flashed in the back of amp and fuse blew. unplugged amp. next day replaced fuse, turn on amp and all tubes glow normally. let warm up for a few minutes then switched standby switch off. all tubes start to glow blue and amp starts to hum again. did this twice, only kept it on for a few seconds as hum got worse and afraid of blowing something up.
diagnosis?
thanks!
diagnosis?
thanks!
