It is currently Thu Apr 26, 2018 12:30 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
PostPosted: Thu Dec 15, 2011 3:11 pm
Hi, i'm new here on the forum
I recently bought a blue stripe Mesa Boogie Mark III (My first Boogie) and I love it! I have heared there are some cool tips and tricks I should try but I don't know them. The only one I know is a 12AT7 in the PI slot. (Is this a good trick BTW??)
So are there any tips and tricks I sould check out?
Thanks in advance,
Maurice
PostPosted: Thu Dec 15, 2011 3:41 pm
I quickly tried a 12at7 in the PI slot and didn't like it, I like it in the reverb slt though. It's a JAN Philips.
PostPosted: Thu Dec 15, 2011 10:22 pm
tung-sol re-issue in v1, fatter speaker wire, keep the presence down to 1 or so.
All boogies go to heaven.
PostPosted: Thu Dec 15, 2011 10:58 pm
+1
Also, if you want your leads to really sing and bite, jump the mids to 6-7 range. You didn't mention if it had GEQ or not, but depending on what you're trying to do with it, try not to bury the 750hz slider as I think it gets too muddy ( I keep mine a touch below the middle line). You can set the rest to taste.
:D
Mark III Cream -Red Stripe DRG
Mark III Cream -Purple Stripe DRG
Orange PPC412HP8
PRS Standard 24 Cream
PRS Standard 24 Red
Marshall JCM800 1960A 412
PostPosted: Fri Dec 16, 2011 1:18 am
Thanks for the replies so far! I'll try keeping the presence down to 1. I still have to
Experiment with the EQ, thanks for the tip on the 750k slider.
I use a nos GE tube in V1 so I won't replace that one with a CP, but it's good to know a Tung-sol RI sounds good in the V1 slot. I will change the speaker wire, that's some great advice. I am mostly going to use the amp as a head, but it's nice to have a better speaker cable for small gigs, when I don't feel like bringing my big speaker cabs. I am still tweaking my settings, but so far I always kept the mid knob around 6-7.
PostPosted: Fri Dec 16, 2011 10:56 am
First off, congrats on the purchase! I'm currently on my second blue stripe Mark III and should never have sold the first. Having owned, among countless other amps, a half-dozen Mesas, including a Mark IV and a two-channel DR, I've come to realize that the Mark III makes the sound that's in my head more closely than any other amp.
All the advice given so far is great. I would add this: when tweaking your amp settings and dialing in your Mark III tone, do it LOUD. Some of the tips here, including the "don't scoop the 750hz slider too badly" and "keep the presence low" (I keep mine around 2.5), really come into play at volume. Low presence may make the amp sound slightly dark when your master volume is at 0.5, but when you crank that MV to 3 at practice or at the gig, the amp suddenly roars to life without a hint of harshness or graininess.
- 1999 Gibson LPC, lefty, SD JB/Jazz.
- Mesa/Boogie Mark III (blue stripe) --> Mesa Recto Standard 4x12
- TC Electronic Nova System
BAND
PostPosted: Sat Dec 17, 2011 6:47 pm
Which socket is the Reverb socket? I'd like to try that. I have a blue stripe too.
One setup I do with mine that REALLY sounds good is this:
Volume 1 - 5-7
Bass - 0
Mids - 2-3 <Rhy2 pulled>
Treble - 6 <Pulled>
Master - 1.5-3
Lead Drive 5
Lead Master 4 <Pulled Bright>
Reverb - 10
Presence - 10
Graphic - <Auto>
set w/subtle V
I use a BB Preamp light gain, medium volume, neutral bass/treble
Mesa C90 in a combo
This sounds amazing close to a Soldano SLO
PostPosted: Sun Dec 18, 2011 9:04 pm
kramerxxx wrote:
...sounds amazing close to a Soldano SLO
^This.
Many of us could give you lots of great settings tips (including some that are pretty much identical to the ones that look like they are straight out of the II-C and III operating manual!) and you can get a slew of tones from "Fender" to "close to a VOX chime" (imho) or Marshall/Soldano, or the random infamous Boogie tones used by greats like Petrucci, Metallica, Santana, Al di Meola, and countless others. The Mark series is so interactive with your guitar/speakers/tubes that when you start tweaking on knobs very slowly it gradually changes the sound in wonderful ways and will effect how you even play. The biggest thing to remember that the amp isn't point and shoot like a Marshall - all the controls interact with each other closely and sometimes honing in on a sound can be a pain or a pleasure! Congrats on the new amp, and if you find yourself looking for a specific tone, odds are someone here has found it, but I think the more fun chase it finding your tone!
Boogie on!
1994 Mark III Blue Stripe 60 watt, R2 vol mod
In his house at R'lyeh dead Cthulhu waits dreaming.
http://www.myspace.com/ytwwvofficial
PostPosted: Tue Dec 20, 2011 10:32 am
[quote=] "SonicProvocateur The biggest thing to remember that the amp isn't point and shoot like a Marshall - all the controls interact with each other closely and sometimes honing in on a sound can be a pain or a pleasure!
Boogie on![/quote]
I think this is the ONE thing that drives impatient players from this amp.
I think that the Mark III is the most underrated amp I've ever owned, played, and/or read about.
PostPosted: Tue Dec 20, 2011 10:34 am
Boogie on!
I think that the Mark III is the most underrated amp I've ever owned, played, and/or read about.[/quote]
PostPosted: Tue Jan 24, 2012 6:31 pm
Yep.
If you turn every knob on a blackface Fender Bassman to 5, it's going to sound great and simply require some minor tweaking to get you to tone heaven.
If you turn every knob on a Marshall Super Lead to 5, it's going to sound great and simply require some minor tweaking to get you to tone heaven.
If you turn every knob on a Mesa/Boogie Mark III to 5 on the lead channel, it's going to sound like poop, and it's going to take you a while to get it sounding better if you aren't used to Boogie EQs or dual cascading gain controls. :D
BAND
PostPosted: Sun Jan 29, 2012 9:41 am
Try using the lead and rythm channels at the same time, sometimes I use it for a subtle lead boost.
90' Mark III Coliseum blue stripe
95 Triple RevG
96' Triple RevF (2)
04' Recto 4x12
07' Recto 4x12-EVM12L's
09' Mills (2)-4X12-V30
96' Explorer
03' Faded V
13' Government V
PostPosted: Sun Jan 29, 2012 1:22 pm
Yeah, that's one thing the IIC+ doesn't have. The III has an incredible amount of gain already but this really puts it over the top.
PostPosted: Fri Feb 03, 2012 2:29 pm
Very interesting : tung sol and fattere wire
What tung sol is recommended ? AX or AT ? and how fat should the speaker wire be ?
Have I to dig out the two inch phone cables out of the road and have the speaker jacks to be replaced to bigger ones.
Cheers
Gear List:
S&W Classic DX, Cal. .44 Magn.
S&W Schofield, Cal. .45 S&W
COLT SAA, 7 1/2", 4th Gen., Cal. .45 LC
COLT Walker, Sign. Ser., Cal. .44 BP
Marlin "Cowboy" 1894, Cal. .45/70
"Yellow Boy" 1866, Cal. .44/40
PostPosted: Fri Feb 03, 2012 2:35 pm
Either is a good tube, but understand that a 12AT7 has substantially less gain (about 30% less) than a 12AX7. 12AX7s are the usual default tube here; you can swap an an AT7 without hurting anything, but it will make a radical difference in the sound and the amount of available gain.
BAND
