Got My IIC+ Headshell From GTS!
gibson5413
I couldn't be happier. What a great job. I liked the combo but love headshell!! I just need to figure out how I am going to fit the reverb tank and fan. I most likely will not install the reverb tank and don't this it is a requirement for the fan (am I wrong in thinking this?).
Either way, big thanks to George!!! Here are the pics of my rig:
Before
After
Thanks guys!
I still have the combo shell and speaker. Not sure what I will do with it (hang on to it or sell it).
gibson5413 said:
Thanks guys!
LMK if you end up selling it!
JSutter said:
Looks good! Nice house too!
Thanks on both counts. Unfortunately I have been relegated to the unfinished basement. The basement should be complete in the next 3 months.
Isn't the short head reverb tank smaller than the combo? That's really a nice headshell.
gts said:
Nope same Tank, Acutronics model 9AB2A1B
Thanks :wink:
gibson5413 give me a call if you want, installing the tank and fan are easy enough and I can walk you through it.
It's really more of a pain in the *** getting them out of the combo shell than installing them in the headshell!
Thanks George! It looks fantastic. I am really impressed wit your work. Sure thing, I will give you a call. Is it necessary to have the fan installed? Do I even need the reverb tank installed if I never use it? Thoughts? Thanks!
gts said:
You don't need to install the reverb tank.
One could probably get away without the fan too but things can get pretty hot inside a head cab.
Maybe others will chime in with an opinion.
I used the MKIIC+ with the fan shut off in the studio. The amp has never failed. The fan does increase tube life from what I know.
I wouldn't run a 4 power-tube head without a fan. It could overhead the pcb and the electronics.
This is probably good advice. I had the fan off in my head for years with no failure, but that doesn't mean you should do it. The fan is a good idea.
Good advice but none of my other amps I have owned over the past 20+ years required a fan with the exception of my Mark series. In addition, the Mark series are pretty wide open compared to most amps that have full enclosure.
I will most likely install the fan to be safe.
Where is the best place to put it on a head? Any pictures I can use as a guide? Thanks!
