mark 3 serial numbers
igfraso
Re: mark 3 serial numbers
Post by igfraso » Fri Apr 12, 2013 5:08 pm
gts,
your comments are always welcome.
I think I saw one serial number 1228x that Boogiebabies said it was an upgraded C to C+ but surely there has to be some 2/84 original C+ amps out there. Please feel free to copy and edit the post with what you have seen/documented. Mine is just a work in progress.
Thank you and best regards
Daniel
igfraso
Post by igfraso » Sat Apr 13, 2013 9:24 am
bartchamdoh wrote:Interesting to see one of the c+ transformers in the 800,s keep it coming guys.
Actually, the X100/X101 (100 W) and the X62 (60 W) were the export transformers for the Mark series from the Mark I up to the Mark III. With the Mark IV, Mesa discontinued the export transformer.
The difference between the X100 and the X101 is:
- the X100 is the older one and the voltage selection is: 117; 200; 210; 220; 230 and 240. It was used on Mark I, II-A and II-B.
- the X101 export transformer has the following voltage selection: 100; 117; 200; 220; 230 and 240. It was used from Mark II-B up to Mark III.
Now, what country uses (or has used in the past) 210 Volt? Maybe selected for some European/South American countries with lousy electrical grid quality and lower than nominal 220 Volt?
The X62 export transformer has the same voltage selection as the X101.
Regards
Daniel
igfraso
Post by igfraso » Sat Apr 13, 2013 1:06 pm
I have been revising some numbers. Here you have my last version of ballpark serial number transitions between Mark III stripes:
- black stripe (3/85 to 1/86): 15001 to 16715
- purple stripe (1/86 to 12/86): 16657 to 19059
- red stripe (12/86 to 1/88): 18949 to 21863
- blue stripe (1/88 to 5/89): 21825 to 24933
- green stripe (5/89 to 9/98): 24898 to 28386
Blue Stripes in 60 W and 60/100 W power amps extend into green stripe territory. It seems that all green stripe were Simulclass and fully loaded (same thing Mesa did with the Mark IV). Amps in head configuration are sometimes out of their own stripe range as well.
Please, keep those odd s/n (manufacturing date included, please) coming.
Regards
Daniel
Daniel
ChrisYoung
Post by ChrisYoung » Tue Apr 30, 2013 9:57 pm
Mk III, Black Stripe
Serial: 16592
Build Date: Jan 1986
Vigo1999
Post by Vigo1999 » Wed May 08, 2013 8:20 pm
- Mk III short head fully loaded simul
s/n: 23728
stripe: blue
Initials: MB
date of production: too lazy to open it :P
- MkIV/A
s/n: 0761
initials: GM
date of production: 10/90
Amps
Stiletto Deuce
Mark III simul blue stripe
Mark IVA
Blue Angel 2x10' combo
Cabs
Mesa Thiele EV
Mesa Open Back EV
Mesa Open Back VS 12 (2)
Guitars
Gibson Les Paul Custom 92'
Gibson Flying V 02'
Fender Am Std Strat 96'
PRS Singlecut 02'
igfraso
Post by igfraso » Thu May 09, 2013 9:55 am
Muito obrigado, Vigo, for the info on your 10/90 Mark IV.
As a separate note, I checked the timeline in the Mesa brochures and I found that they put 1989 as the initial date of Mark IV manufaturing. Yet, that timeline is a little bit inaccurate. It states:
- Mark I: 1972
- Mark II-A: 1980 (instead of 1978)
- Mark II-B: 1982 (instead of 1980)
- Mark II-C: 1983
- Mark III: 1986 (instead of 1985)
- Mark IV: 1989
Regards
Daniel
Vigo1999
Post by Vigo1999 » Thu May 09, 2013 9:57 am
igfraso wrote:Muito obrigado, Vigo, for the info on your 10/90 Mark IV.
De nada Daniel! 8)
Amps
Stiletto Deuce
Mark IVA
Cabs
Mesa Thiele EV
Mesa Open Back EV
Guitars
Gibson Flying V 02'
PRS Singlecut 02'
MikeMax
Post by MikeMax » Wed May 29, 2013 11:54 pm
For those keeping score at home, I have a Mark III short head with serial# 22671 Blue Stripe. It is Simul Class and has 60/100 W switch, no EQ. Has R script and MB, and a plugged hole marked Reverb on the rear panel next to Presence.
Looks like 11/98 date code.
Never really have been happy with the sound, it is very flat sounding, not live at all. I have tried Mesa tubes and JJs.
Paul Johnson
Post by Paul Johnson » Sat Mar 04, 2017 10:41 pm
First Mark III was a fully loaded head (except A/C plug). Serial number was 15924. She is gone now...nothing ever compared to its performance and tone.
My present Mark III is a blue stripe combo that pales in comparison to my first Mark III. Its serial number is 226??. MB's initials are inside and under power cord. It was built in April of 88.
fretout
Post by fretout » Sat Mar 25, 2017 1:34 pm
I'll add in a few more Mark IIIs I have. They seems to fall into the ranges alradh listed...
Mark III Blue Stripe Simulclass - 226XX dated 09/88
Mark III Coliseum Blue Stripe Simulclass - 231XX dated 06/88
Mark III Coliseum No Stripe Simulclass - K5XX dated 09/85
Mark III Coliseum KDRG | Mark III+ Coliseum KDRG | Mark III DRG | Mark IV (Head) | Mark IV (Combo) | Dual Rectifier Revision D | Dual Rectifier Revision G
jhreid
Post by jhreid » Sat Apr 08, 2017 10:17 am
My purple stripe is 16750.
Mark III Purple Stripe Simul Class
Fender Stratocaster - EMG DG20
Guild X-175B
Tokai ES-100 - Gibson Burstbuckers
Jackson DXMG - EMG 81/89
igfraso
Post by igfraso » Sun Apr 09, 2017 12:29 pm
What date is your purple stripe #16750?
Thank you
Daniel
Philippe
Post by Philippe » Mon May 22, 2017 3:37 am
Mark III hardwood combo fully loaded
s/n: 25217
stripe: Green
Date of production: 4/89 (I'm not 100% sure if it's a 4 or a 6 on the chassis, so it could also be 6/89)
Initials: MB
Wiring: Kaydee
Date of wiring: 6/14/89
Mark III red stripe DRG medium head
Mark III green stripe DRGX hardwood combo w/ EV12L
gratefuljed
Post by gratefuljed » Tue May 23, 2017 8:01 pm
All fully loaded...
Black dot 16478 1/86
Red stripe 19798 cant see date
Blue stripe coli 24146 1/89
lost in the land of enchantment...
lovetoboogie
Post by lovetoboogie » Tue May 23, 2017 9:11 pm
I currently have in for servicing and sale an 89' Blue Stripe...
5/89
Serial# 25149
HRG
100/60 Non-Simul, Reverb & GEQ
Wood/Wicker
*The wood cab is made from Shedua, also known as Ovangkol. A now rather rare African hardwood.*
