MarkIIC+ FX loop trouble - HELP
djemass
France
Hi,
The FX Loop of MarkIIC+ sounds strange. As it is a serie loop, normally, 100% of the signal goes in the FX Loop when it is engaged.
However, this is not the case.
I did a test:
I plug my guitar in Amp IN
then, if I plug a jack in the FX SEND and nothing in the FX Return, the sound stays exactly the same. That means that connecting a jack in the FX SEND doesn't engage the FX Loop...
the problem is that when i plug a jack in the FX Return and nothing in the FX Send, normally, the signal should be totally muted. But I still have something like 10% of the signal...
The problem is that I can't use a volume pedal in my fx loop to make volume swells for instance.
HELP !!!
KR
Gerald
Hi Gerald,
You've stumbled upon a design flaw concerning tube powered serial loops, where about 5% of the dry signal can be heard and you can't get rid of it.
Cause: there are in fact two tubes inside the case of a 12ax7 tube. Each side's called a triode, and each can be used as a separate amplifier stage. However because the triodes are close together some signal bleeds through between the two halves. With the IIC+, the tube responsible for the effects loop is V2 - with the two halves being V2a & V2b respectively. V2a amplifies the signal before the effect send, and the V2b buffers the returned signal. So there is actually a small amount of unwanted parallel signal bleeding through between the V2a (send) and v2b (return).
I suppose the ideal solution would be to add another totally dedicated tube instead of either V2a or V2b, or re-wire the preamp to change the order of connectivity of the tubes in the signal path, which's easier said than done!
jvk said:
Hi Gerald,
Cause: there are in fact two tubes inside the case of a 12ax7 tube. Each side's called a triode, and each can be used as a separate amplifier stage. However some signal bleeds between the two halves. With the IIC+, the tube responsible for the effects loop is V2 - with the two halves being V2a & V2b respectively. V2a amplifies the signal before the effect send, and the V2b buffers the returned signal. So there is actually a small amount of unwanted parallel signal bleeding through between the V2a (send) and v2b (return).
Thanks my friend for your support as usual !!
Take care
G
