They don't sound "exactly" the same. Each will have slightly different components here and there to make them sound unique. For example, maybe Mesa used a different value resistor on this C+ whereas they used another value on the next, simply because it was laying on the table.
Further, you have the different options: simul-class, 60watt, EQ, etc. These have an obvious effect on tone.
The bottom line though is that all C+'s have the same inherent tone and the differences are minute. It is not worth the time, money, and effort to try them all out to see which of the little quirks fits you best. The main differences you need to decide on are EQ vs No EQ and Simul vs No Simul. The rest you forget about or it'll drive you nuts. After you pick one up, post your circuit board pictures and some of the experts will tell you if there have been modifications, which are all usually capable of being reverted back.
