suggestion for compressor for IIC
Well, this was for a Mark III, so hopefully close enough...
Recently bought a Retro Sonic compressor here in Ottawa. Hand made, true bypass, etc...
I demo'd it against a Keeley (4 knob), Diamond and Barber Tone Press and it more than held its own (and was a bit cheaper than the latter two and much cheaper than the Keeley).
Have it in the signal chain now and it's quiet and very usable/versatile. Only after I bought it did I realize that RetroSonic is made here in Ottawa, though I've seen it on ProGuitarShop.com Stateside.
Just my $.02
BTW, the Retro-Sonic Chorus and Distortion sound great as well.
compressor:
cut and paste from earlier time:
i had a dynacomp for 10 years.
then i tried a barber tone press, and was absolutely sold.
i a/b'd it against a Keeley compressor.
here's my review:
got to a-b a Keeley compressor against a Barber tone press
:D
both of these, are guitar player magazine editor's choice award winners.
my luthier, bought a keeley comp.
i bought a Barber tone press.
we got together last night and a/b'd the two-- same rig, same guitar, same settings, etc.
gotta say, they're both amazingly good sounding compressers.
both are pretty transparent.
both are dirt simple to operate.
both have true bypass. you don't hear them in line at all, when the effect is off.
all other compressors, i've ever tried, sucked tone when off.
both have led's to show when the effect is engaged.
both are made very well.
the barber is bigger, and a bit heftier, than the keeley. i like heavy, myself, but if it was an issue of fitting a smaller pedal on a pedalboard, the keeley has the upper hand.
$219
the keeley, is based somewhat on the mxr dynacomp.
i had a dyncomp, til about a month ago, so i'm well versed in the feel of that classic comp.
the keeley, is more transparent, and not quite as noisy, as the original mxr dynacomp.
the keeley has more aggressive settings on the sensitivity, and gets pretty noisy when dimed (completely understandable with high settings of ANY compressor).
-but the middle settings sounds really nice, and even at really low settings, you can get very transparent compressor settings. Still, you can hear a certain amount of 'pop' at the harder pick attacks, and this is very much in line with the classic dynacomp sound....and it still sounds 'squished' to my ears...... it's more obvious that this effect is on, even on mild settings, than what is achievable with the tone press.
it has an 'attack' control, inside the box, that can be tweaked to a degree, but is somewhat a nuisance to get to and mess with...
we left this set on the factory setting for this test.
the barber Tone Press, can do this same sound, but has a completely other side as well....
it can do "Parallel compression".
and it works.
website defines it best:
Barber developed a one-of-a-kind and quite proprietary continuous “blend control” circuit and combined it with a discrete “Class A” FET mixer circuit to allow you to continuously blend the natural signal of your carefully selected guitar with a “phase-corrected” classic compression circuit.
basically, i can dial in the amount of compression (sustain) i want, then take the blend knob and dial in the straight, dry unaffected guitar signal along with the compressed signal.
this allows me to set the compressor so i get exactly the amount of 'attack' i want, and it comes through without being squished.
when i first plugged it in, it almost seemed like the compressor was not doing anything...
because you hear all of your original attack, and with typical compressors, you hear the compressor working on the signal right away. i had to leave that session, come back later with a different mindset, before i really became aware of how this thing really works.
--with the tone press, it's very subtle how it's working, and doesn't mess with the basic tone and dynamics as much, based on how you set the blend control. but you still get all the compression you want, it's just way more dynamic.
it seems to enhance the tone as well, meaning, it doesn't 'take away' any of the treble or bass response. you can turn the blend all the way to the right, and get the 'dynacomp' sound if you want it.
but i'm finding, the unique sound of this compressor has allowed me to dial in a much more natural sounding effect.
it sounds perfect for strats.
i back it down a bit for humbuckers....... which is as easy as just dialing the 'blend' knob back a notch or two.....
a side benefit of this pedal...
you can use it as a class A 'clean boost'.......... with 8 db of boost, and the blend all the way to the left.
there is a 'color' trim pot inside the box. you can tweak this to give a more round vintage sound. i like it in the factory 'full on' setting.
$139.95
for the price, i think it's a no brainer.
YMMV
Gonzo, you're right about the Tone Press (I accidentally called it a Tone Squisher above). It was a cointoss between what I got and the Barber... If it was an odd day, might've gone out with that one, but the $20 off the Retro-Sonic sold me that day.
You couldn't go wrong with the Barber.
