what to look for when buying used?
fatoni
Post by fatoni » Fri Dec 26, 2008 1:51 am
im looking at trading a med. head for a short head. i know mine is fine because i bought it from mesa. its my only tube amp and i dont really know what to look for when shopping used. when i go check out the short head is there anything i should be looking for that would make a straight trade stupid? what are some common problems that i should be looking to avoid? thanks in advance
Db||---------AhGpG--------||
Ab||-------W--------O------||
E ||------L------------N----||
B ||----U---------------E---||
Gb||--A------------------R--||
Db||P------------------------||
Bobby Marshall
Re: what to look for when buying used?
Post by Bobby Marshall » Sat Dec 27, 2008 5:52 am
fatoni wrote:im looking at trading a med. head for a short head. i know mine is fine because i bought it from mesa. its my only tube amp and i dont really know what to look for when shopping used. when i go check out the short head is there anything i should be looking for that would make a straight trade stupid? what are some common problems that i should be looking to avoid? thanks in advance
Here is my 2 cents on what to look for
I would definitely pull out the chassis and look inside to check for rust, obvious repairs and damage, etc. If the tolex is original and in good shape that would be a good sign. Dented head cases and ripped tolex is a sure indication of neglect and/or abuse.
I would also play her with your guitar, cables (instrument and speaker) and speaker cabinet using the settings you currently use on your medium head. Play at stage volume too.
Bring a standard footswitch with you to make sure all the footswitch switches in the back work. Also bring your FU-3 and make sure all the switching works with yours and his on the short head.
Now I just want to add a few other comments about why you would make this deal.
1. The medium head has more of the switches on the front (I believe) so I would personally see that as the more favorable model, unless point 3 applies.
2. I owned a short head Mark IV B for over 5 years. For a small lady she was heavy as a F-150. I can't imagine the medium head is much heavier. If you are trying to go lighter I would think you would only save a few pounds.
3. The only reason I would trade a medium head for a short head would be to rackmount it. If you ain't gonna rackmount, I don't believe the short head gives you any advantages over the medium head, but what do I know.
Well that's my 2 cents. Hope it helps you with your decision making process.
"Be excellent to each other." - Bill and Ted
fatoni
Post by fatoni » Sat Dec 27, 2008 5:52 pm
super helpful, thanks a bundle
Elpelotero
Road King
Post by Elpelotero » Wed Jan 14, 2009 11:40 pm
twist all the knobs to make sure they do what they should
'92 Dual Recto Rev. D, Volume mod
'84 Mark IIC+ Coliseum
'85 Mark IIC++ DRG, V1 mod
Mesa Standard 4x12
1980's EV Thiele
Sold:
'92 Dual Recto Rev. C
'92 Dual Recto Rev. E
'05 Dual Recto 3ch
'84 Mark IIC+ DR
http://www.TheBoogieArchives.com
