Help verifying which version Mark-IV head I have
phrygiandom
Post by phrygiandom » Fri Nov 28, 2008 6:18 pm
Hello,
Today I won a 1990 Mark-IV head off Ebay. After winning, I got more pictures from the seller and went about trying to determine which version it was. I noticed a couple of things that didn't make sense.
First, here are two pics:
Front
1. On the front, there is a blue LED on the far right and the two rockers near the 5-band EQ. Is this correct?
2. On the back, there is a ground lift toggle on towards the left side. Is this correct?
I wanted to make sure that there weren't any mods done. Any help would be greatly appreciated.
Dave
Mark-IVA Head
Egnater TOL-50 Head
Peavey Windsor Head
ADA MP-2 Preamps/Peavey Classic 60/60 Power amp
Avatar & Genz Benz cabs
6L6C
Re: Help verifying which version Mark-IV head I have
Post by 6L6C » Fri Nov 28, 2008 7:01 pm
You forgot to post the pics
DCR-1SR rack wah > GRX4 (router) In the loops before preamp
Keeley compressor
BB Preamp
EVH Flanger
Mark IV - Axe Fx std - 2x12 Recto (Warehouse Veteran 30's)
Controlled by Rocktron All Access
phrygiandom
Post by phrygiandom » Fri Nov 28, 2008 7:06 pm
I did some more intensive searching on the net; I think it's an "A" based on some pics I found.
You can click the "front" and "back" to link to the pics. I never know how big they're gonna explode if I insert them, so I just linked to them.
Dave
Mark-IVA Head
Egnater TOL-50 Head
Peavey Windsor Head
6L6C
Post by 6L6C » Fri Nov 28, 2008 7:47 pm
Dave
Ooop's my bad! Didn't notice the link's.
And yes you are correct its a "A"
And looks in fantastic shape!! Good luck with it and welcome to the board.
John
Keeley compressor
BB Preamp
EVH Flanger
EirikBrandal
Post by EirikBrandal » Sat Nov 29, 2008 4:23 am
absolutely an A, as you can see on the two mono FX loops in square form, rather than the stereo loop with triangle shape on a B
PRS Custom 24 w/ lundgren M6
TC Electronics Nova System
MI Audio Tube Zone Overdrive
Mesa/Boogie Mark IV
4x12 Standard Rectifier Cabinet
http://www.hamuemon.moo.no
http://www.myspace.com/hamuemon
phrygiandom
Post by phrygiandom » Sat Nov 29, 2008 8:48 am
They seem to be more and more difficult to find for sale these days, I had to finally jump on one.
I understand that it's an 18 year old amp and that it won't be absolutely pristine on the inside, but should I be concerned about corrosion/rust? Here's what I'm talking about:
Power tubes
Seller told me that the amp/footswitch work 100% and that it'd been recently serviced so there aren't any worries there; I'm just talking about future "preservation". Any thoughts?
Dave
Mark-IVA Head
Egnater TOL-50 Head
Peavey Windsor Head
Xqzdust
Post by Xqzdust » Sun Nov 30, 2008 7:04 pm
Definitely an "A" just from the date. I'm surprised no one mentioned the meaning of the two rocker switches on the front panel but, you have a wide body head. Hope you didn't have plans for a rack mount. Other than that it means you can get to those two switches easier. I have an early nineties "A" combo that I bought on Ebay and have had no problems with it other than FedEx inflicted injuries! LOL. If you have the time/patience I would advise getting a road case sent to the seller and have him ship it in that.
good luck and enjoy it!
'66 Firebird (like Gatemouth's)
'68 Goldtop w/p-90's
'85 Cherry red 335 dot neck
'86 Cherry sunburst Les Paul
'08 Clapton Strat (Black sheep of the family!)
'11 Martin HD-28 (Suh Weet!)
'?? Mark IV A in Koa w/matching Theile!
ANIMATED SUSPENSION
Post by ANIMATED SUSPENSION » Thu Dec 18, 2008 5:01 am
phrygiandom wrote:They seem to be more and more difficult to find for sale these days, I had to finally jump on one.
Power tubes
Dave
Those power tubes are in the wrong positions !! :shock: Even if they are the same colour codes, you should really have the STR430's and STR440's operating as pairs. The two centre tubes operate as a pair and the two outer tubes operate as a pair. Swap them over asap !!!!
Ibanez RG8270VV
Ibanez RG8470FE
Ibanez RG8570TT
Ibanez RG2620CBL
Musicman JP6 Pearl Redburst,inlays,headstock
'91 PRS CE24 Maple Top Grey Black
'93 PRS Cust 24 Whale Blue Quilt,Birds
Mk IV Medium Head
Single Rectifier Head
4x12 Recto Std Cab
MrMarkIII
Post by MrMarkIII » Thu Dec 18, 2008 6:09 pm
ANIMATED SUSPENSION wrote: Those power tubes are in the wrong positions !! :shock: Even if they are the same colour codes, you should really have the STR430's and STR440's operating as pairs. The two centre tubes operate as a pair and the two outer tubes operate as a pair. Swap them over asap !!!!
Try to imagine all life as you know it stopping instantaneously and every molecule in your body exploding at the speed of light. :lol:
phrygiandom
Post by phrygiandom » Sat Dec 20, 2008 11:02 pm
Those pics were taken just prior to him packing it up for shipment. He had it checked by someone and they installed new 440's...probably not knowing the pairing pattern.
I noticed the incorrect pairing too, and swapped them out as soon as the amp arrived.
This amp sounds GREAT!!
Dave
Mark-IVA Head
Egnater TOL-50 Head
Peavey Windsor Head
zebpedersen
Post by zebpedersen » Sun Jan 04, 2009 5:53 pm
That's my short-n-sweet test for whether it's a decent example :) none of this techno-stuff! As far as rust goes - obviously it's not desirable, but I've seen 10+ year old IVs and plenty of I - III Mark-series which aren't exactly in perfect physical condition go out to battle every night with no problems.
Mark I HRGX 15"
Mark IIC+ DRG
phrygiandom
Post by phrygiandom » Wed Jan 07, 2009 3:08 pm
Actually, it looked quite clean when it arrived. Gonna try to get "GTS" to give it the 'once-over'...new tolex and cane grill.
I can't imagine myself EVER getting rid of it.
Mark-IVA Head
Egnater TOL-50 Head
Peavey Windsor Head
