My F-100 only works at full volume.
bluez
Norway
When i put the gain and master volume on max and play a chord it output is normal ( very loud ) as i turn down gain or the master volume there is a point where the sound goes on and off, and cracles. It's the same for both channels.
I have replaced alle the tubes with new ones. If i use the headphone out speaker the problem is still there. I have tried a cable from send to return, still the same problem.
