Hi Folks: I've never used the effects loop before that has a mix control. What is everybody doing as far as level. I've tried most of the knob range and I seem to like 50-75% with my current levels on my pedals. Do I cut all the levels ON THE PEDALS UP and use the mix control on the FX loop or just balance between them? (chorus, 12-string effect, delay and digital reverb)
Thanks, great to be back in Boogie-land
Shaun
F30 Effects loop question
Tom Anderson Hollow Droptop Classic
Fender Baja Telecaster
F-30 112 Combo
Peavey Classic 30
Barber/MXR/ Electronics
F-30 112 Combo
Peavey Classic 30
Re: F30 Effects loop question
50-75% is what I use as well..seems good to my ears.
PRS Custom 24 - PRS CE 22 - SVL 61 Reserve Stratocaster with SVL 59 Reserves - Fender 57 Reissue Strat with SVL 59 Reserves - Lowden O23 - Lowden F32cx - Takamine TNV 460SC - Tokai LSF 100 Les Paul - Levinson Blade Strat - Mesa/Boogie F50.
- Bottle Rocket
Keep the mix level on the effects at 100%, and the mix level on the amp at about 15%
- elvis
- Donating Member
For analog effects, you can either set the loop Mix to 100% and then set the pedal mix how you like it, OR set the effects mix to 100% (or whatever you like) and set the amp mix how you want.
For digital effects (delay, mod, reverb, etc) you will want to set the amp mix to 100% and set the effects mix as appropriate. If you don't run the amp mix at 100%, then you will likely get a flanger-like artifact due to the latency in the digital effects.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
Recto 2x12 Vertical
Recto 2x12 Wedge
- Bottle Rocket
The following is cut/paste from the manual, if that helps -
For the best results...Set the mix of your effect to 100% wet. Then dial in the amount of effect that you wish to hear,
starting at 10% with the FX LOOP MIX control. The drier (closer to 10%) signal you use, the better your tone
should be. This parallel type FX Loop allows the amplifier to retain its purity with the smallest amount of degredation
due to possible effect impedance mismatching.
