F-50 maybe ruined by new owner
F-30, 50 and 100's
Oldmactech
Post by Oldmactech » Tue Jun 21, 2016 9:13 pm
Took in an F-50 combo yesterday, good price, no known history.
Tested 100% on acquisition. As part of the negotiation I pulled the power tubes to see if any were original. No, Sovteks. Replaced the tubes, bought the thing, drove off.
Next day, went to fire it up, blew a fuse. Uh, oh. Replaced the fuse, two down.
Symptoms: power light on, I hear a relay click.
Pulled the chassis from the combo and noticed one burned and one burned and missing (diode?) on the daughter board that the power tube mounts are attached to. I have pictures but will post later.
After rethinking the problem it is apparent that I mis-aligned one or both of the tubes in the tube mount and fried something. Alignment Keys on the bottom of both tubes are missing? So far looks like simple resolder job to reattach a diode. (Need the spec) and probably replace the power tubes will save it.
Any tips (especially the diode spec) are appreciated.
Jb
Oldmactech
Re: F-50 maybe ruined by new owner
Post by Oldmactech » Tue Jun 21, 2016 10:13 pm
Minor update- looks like one or two 470 Ohm resistors are fried.
Need a source for these.
Jb
Don
Post by Don » Wed Jun 22, 2016 1:35 pm
You should be able to get them at Digikey, Mouser, Antique Electronic Supply. Stick with the same wattage rating (2 watts?). Antique Electronic supply sells replacement guide pins. I've used them to make an old RCA 6L6GC safe to use.
