F30 tubes
osafer
Athens - Greece
Hi,
I own an F30 (with original preamp tubes). I used an eq pedal before the input to boost the bass freq (around 100-200Hz) on the clean channel, and I realised that the sound was getting a bit cranky on the bass section, as if the gain was too much (gain 3 o'clock, bass-mid-treb 10 o'clock).
Do you have to propose any preamp tubes that would probable reduce the gain and get me a cleaner sound?
Cheers
I use the same amp (with customized tubes) and all that I can say is that the V30 speaker is not designed for a good bass response unfortunately. Another HP combined with V30 like the mesa Thiele (with a celestion C90 speaker) would give a much better hotter sound.
