Mesa F-30 footswitch issue....
jake_the_pake
Hi all,
I think my footswitch may well be self aware as it seems to have developed an issue right as I'm in the process of beginning to replace it with a midi set up.
Footswitch has 3 buttons - channel select, contour on/off and reverb on/off. Contour and reverb switches working find but the channel selection has stopped working....no LED light, no effect on channels.
Please tell me this is just the footswitch/cable and not my amp that has a problem! I've checked all connections a few times and the switch on the amp that selects footswitch use. Also had a look in the jacks of the cable and there seem to be no bent/broken pins.
Any help would be greatly appreciated!
Thanks
A bit late and maybe too obvious but is the mini toggle switch on the amp front pannel on the lead/footswitch position?
