F50 COMBO WHITE NOISE
F-30, 50 and 100's
zombywoof
Post by zombywoof » Fri Dec 31, 2010 9:01 am
Hi
Has anyone had any luck getting rid or reducing the background waterfall/white noise sound on the channels.
I have tried chaning valves (Tungsols to JJ's), my Tech guy says its a design fault,.
Any help would be apprecxiated.
Thanks
Tmuggie
Re: F50 COMBO WHITE NOISE
Post by Tmuggie » Sun Jan 30, 2011 4:36 pm
I have been having the same issue with mine too. I don't remember it doing that when I bought it...I bought it used by the way. Seems like I started noticing it when I changed a pre amp tube...v1 I think. I had taken it out of a vox tonelab. The tone lab started acting up too....and the reverb on the amp quit working all about the same time....I am thinking it may have been a power surge or a transient or lightning maybe. Also...if you have computers, cell phones or lights on dimmers on the same circuit or near by, it will cause all sorts of problems. Have you ever put your cell phone close to your pick ups??...lotta weird bleeping, blooping and chirping going on......however....the noise that you speak of does it with out anything plugged into the amp, mine does anyway which indicates to me that it is in the amp or the power supply.
Tmuggie
Post by Tmuggie » Mon Jan 31, 2011 8:36 pm
I was fooling around with my f212 combo last night. I noticed that I had forgotten to put the tube retainers back on. I replaced them and alot of the noise I was getting went away. I was getting alot of random static-ee popping sounds...not real loud but loud enough to be annoying as hell. I still have the white noise though. Maybe a power conditioner would eliminate a lot of that noise??
stevethebeeline44
Post by stevethebeeline44 » Fri Aug 26, 2011 10:13 am
I have had the same problem since I got it. Purchased on eBay in 2007 from USA and shipped to Ireland.
Anyway I doubt I'll ever buy and amp on eBay again! :( Got a great
deal but I came across a F50 in one of the guitar shops in London on
Denmark St. I asked to check it out, not to play it just power it up
and listen for noise when idle. Not a peep out of it! So there is
defo something off with mine. Glad to hear there are others that have the same problem, at least I'm not alone. I do love this amp with the constant background noise is a real let down. Not so bad when jamming / playing loud live gigs but home and studio recording are negativly affected by this!
Sorry I haven't any advice to offer only to chime in to say that it's obviously a problem that other F50 users are experiencing.
Could MESA reply with any suggestions? I know I have the inspection tag with my F50 and there is no way it left the factory with this white noise/hiss issue.
Thanks,
Steve
elvis
Post by elvis » Mon Aug 29, 2011 11:58 am
These amps are really gain-heavy. A lot of the noise is pickup and cable noise that gets amplified. Most people tame it with an NS-2 or decimator. You may have a noisy preamp tube as well. Mesa sells tubes they call SPAX7 that are very low noise. HOWEVER, they are also very low GAIN. So that should tell you something.
Mini Rectifier blue LED
Stiletto ACE
Recto 2x12 Vertical
Recto 2x12 Wedge
mididoc
Post by mididoc » Sat Jun 08, 2013 11:13 am
Hi,
if you have white noise problem on clean channel,
try this:
http://www.mididoc.com/f30-mod.htm
Good luck.
8)
bluez
Post by bluez » Wed Aug 07, 2013 4:52 am
Try changing the V1 tube. I think i had this on my F-50 years ago, and it solved the problem.
If you can, move the preamp tubes around until you can find the one with the least amount of noise. The V4 tube (Phase Inverter) affects your tone the least, so try using that one. I have bouth the F-50 and F-100 (European bought), and they are bouth less noisy than any Fender tube amp i have.
Authorized Boogie
Post by Authorized Boogie » Wed Aug 07, 2013 11:00 am
bluez wrote:Try changing the V1 tube. I think i had this on my F-50 years ago, and it solved the problem.
+1! A noisy tube in V1 will get amplified and create more noise. Simply find the least noisy tube for V1, and of course check all other preamp tubes for an suspects.
UKBoogieboy
Post by UKBoogieboy » Sat May 28, 2016 8:23 am
https://youtu.be/A7VgAhPdoYs
I've got an F50 and 5.50. They're both like it. I'm thinking of selling them both.
Nick79
Post by Nick79 » Mon Nov 21, 2016 6:24 am
Yes, mine was noisy as hell, so much so i was quite concerned there was something majorly wrong with it.
But after changing the pre amp tubes its now silent, i put Tungsol's in v1 and v2, and JJ's in v3 and v4. For V1 i paid a bit extra and got one that was low noise, did the trick and still cheaper than the Mesa spax7.
