Is the F-30 combo amp midi controllable?
Frankenmuth,Mi. USA
Hey everyone i have a question and i was hoping someone would know the answer.
Is the F-30 combo amp midi controllable?I want to use a midi controller to change the channels on the amp and control my effects too.
I have a T.C. Electronic Nova System multi-effects unit that has 2 midi connections.
Just curious.
axess cfx4 or rjm mini amp gizmo will allow it to be midi controllable.
N
Don't forget that, the socket is like a midi socket (d something sub or what they are called). As a result you can directly connect a unit like the tc g major and do 2 relay switches along with any effect on off.
That only means that with the g major you can change channel, contour or reverb plus chorus/delay/compression eq all by on midi foot controller if that is what you mean. I don't know if this is the case with other processors.
There is a whole thread about f-series and they show you how to do it. Google mesa f-series lounge harmony-central.
