Problem with F-100 combo i've just bought....
rumpelstiltskin
Just bought an F-100 combo off Ebay.Problem is after noticing several valves were slightly loose because of transit i can easily crank the thing up full volume on the 60 and 100 watt selections and my neighbours would barely hear it,it's that quiet!!Don't know what in the hell could be wrong?Guy said in auction he had just renewed the power section valves so i have to take him at his word.All valves in the preamp section too seem to be lighting up,can valves still light up and give little power?
First, try a different speaker.
Second, reach around back and plug both ends of a guitar cord into the loop in and out.
You should be peeling wallpaper with that amp.
And also make sure that the FX mix knob is at least 12:00. The knob on my F30 was turned down and I had the same thing happen.
