I'm downsizing from JCM800's as although i love that sound, they're just too powerful.
I briefly owned a deuce a while ago, but not long enough to really test it out.
I've got the option to buy back my old deuce stage 1 rig, and I've also got a lead on a ace stage 2 head.
My question is, how usable is the volume on these amps?? My JCM800's only started to "work" when they got above 2 on the volume, which is too loud for a lot of places, I wondered if the stiletto was the same or if the volume was usuable for home as well as through to small or larger gigs.
Stiletto Ace and Deuce , how useable is the volume for smaller gigs??
- Bottle Rocket
- Mark II
Re: Stiletto Ace and Deuce , how useable is the volume for smaller gigs??
In my experience, my Deuce II was pretty useless in a home/quiet environment. It needed to be cranked to deliver the goods.
Mesa Boogie Lone Star Classic, Stiletto Deuce II, TA-15
Mesa Boogie Lone Star 4x10, Lone Star 27 1x12, Recto Compact 2x12, TransAtlantic 1x10
You can set your power tubes to 50W for smaller gigs but they are still loud.
Rich
Mesa Boogie Stiletto Stage 1
Laney AOR 50
Ibanez RG550
ESP LTD EC-1000
MXR Overdrive
Crybaby Wah
Laney AOR 50
Ibanez RG550
ESP LTD EC-1000
MXR Overdrive
Crybaby Wah
- elvis
- Donating Member
I'm using my Ace quite a bit at home. I have to get it up a bit too loud at home to really open it up, but I'd call it small-gig friendly. Between the gain and modes, you should be able to get giggable dynamics.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
Recto 2x12 Vertical
Recto 2x12 Wedge
- Mark II
With the Spongy variac and tube rectifiers, you can definitely get some great sounds for smaller gigs.
ALSO, when the effects loop is not bypassed, you can actually use the Send control as a kind of "second" master volume, as it is always in the circuit. So you can get a bunch more preamp tube saturation if you want.
Guitars: Hamers, Heritages, G&L Legacies, EBMM Steve Morse, Carvin Bolt, Fender Tele
Amps: DC-5 1x12, Maverick 2x12, Stiletto ACE 1x12, Trem-O-Verb 2x12
