It is currently Fri Jun 22, 2018 11:46 am
 Post subject: Stiletto ACE fx loop
PostPosted: Thu Mar 08, 2018 3:47 pm
Hello,
I am new to the board, I have looked on here for years but just joined today. I have owned quite a few boogies, currently I only own the 50 watt 2x12 Stiletto ace. I have rarely used FX loops because I basically use reverb and some overdrive pedals, sometimes a clean boost and most amps I have owned have had reverb on board, Electradyne, and LSS more recently. However, obviously the SA does not. I have been using it for reverb and delay and now it won't work. I put the pedals through the loop and nothing, no volume, no sound. I bypass the loop and it cranks just like nothing is wrong. Anybody know what could be gong on?
 Post subject: Re: Stiletto ACE fx loop
PostPosted: Tue Mar 20, 2018 1:12 pm
Hey there! Try this: Use some contact cleaner (e.g., Deoxit D5), spray a 1/4 cable and push it in/out of the send and return jacks on the amp a dozen times or so. You can spray as much as you want - it shouldn't hurt anything. Let it sit overnight with the cable in.
Both my Ace's (combo and head) had this issue and this fixed it. The switch in the return jack (or maybe the send jack, not completely sure which is why I did this for both) can oxidize over time if not used much or at all. This procedure cleans that switch and lets the engage/bypass function properly.
Can't hurt. Please tell us if it worked :)
And now for something completely different...
cron
