someone turned the combo into a heas versio , got a killer deal for it.
first thing i did was swap out the preamp tubes to tungsol, jj, penta, penta and sovtek lps which really brought the amp to life.
now i just gotta figure out my cab situation.
speaker suggestions for mesa stiletto ace?
I play a mix between alternative and modern rock. I play 75/25 ratio dirty to clean. I wanna replace the speakers in my 212 cab which are currently eminence legends. the cab is front loaded if that makes a difference.
the amp only has 4 & 8 ohm outputs. cab is currently rated 8 ohms.
first question, should i go for two 8 ohms for a 4 ohm load or two 16 ohm for an 8 ohm load? how much of a difference will that make?
second question is since my amp is picky on speakers what would you suggest? first thought was a mix of vintage 30 and a g12h30. open to other siggestions such as full set of v30s or c90s or whatever.
