It is currently Wed Feb 21, 2018 8:32 am
Post new topic Reply to topic  [ 14 posts ]
 Post subject: Overdrive pedal for ACE?
PostPosted: Sat May 09, 2015 10:19 pm
I'm so used to using EL84 amps for the last several years that I'm at a loss when it comes to my new Ace head. I have a Sparkle Drive, but I'm wondering if there's a better fit. Mainly using to boost the crunch mode. Thanks!
Guitars: '93 Gibson Les Paul Standard, Breedlove c250/eo
Amp: Mesa Stiletto Ace, Mesa Vertical Rectifier 2x12
Effects: Crybaby, Sparkle Drive, Flashback
PostPosted: Mon May 11, 2015 6:28 pm
BB Preamp or a little known Gem, The Electro Harmonix Soul Food for less than $70
Mesa Triaxix 2.0 non fat
Mesa Roadster 2x12 Combo
Mesa Stiletto Ace 2x12
Mesa Rectifier Recording
Mesa Simul 2:90 Blue Light
Mesa Dual Rectifier Roadster 2x12 Combo
2 Mesa 2X12 Recto Cabinets
PostPosted: Thu May 14, 2015 12:32 pm
I've had a BB Preamp and a Timmy on my board for over a year now. I like both of them with my Deuce.
Stiletto Deuce II, with bias mod - 2x12 Recto Cabt. Scumback M75s inside
Budda Superdrive II 45
’79 Gibson Les Paul Custom Silverburst
’85 Gibson SG ’61 Reissue
Fender American Standard Stratocaster and Telecaster
PostPosted: Sat Jul 25, 2015 12:34 pm
Mystical Overdrive, or Crème Brûlée.
Mesa Rectoverb 25 w/Mesa 1x12 ported (C90)
Mesa Mark V:35 head w/Mesa 1x12 ported (V30)
Various Ibanez guitars
Warmoth custom soloist
PostPosted: Wed Aug 26, 2015 1:00 pm
I'm pretty simple. Fenders = Tube Screamer Gibsons = MXR Zakk Wyled OD either set up: >40% Gain, =50% Tone, <50 Level. I use both pedals as a boost and the amp grows teeth. At over 40% gain, the amp sounds great alone but seems to thin out from too much grain in the distortion. When recording, if you run the gain at 30% and double track the guitars the sound gets huge and cuts right through a mix.
PostPosted: Mon Aug 31, 2015 1:02 pm
Using a Catalinbread Dirty Little Secret feeding the front of my Ace. My other pedals thru the loop...seems a little quieter this way. That DLS pedal is working out well so far- giving me lots of juicy Super Lead tones!! :mrgreen:
'95 LP Standard, '11 Gibson SG Jr Reissue, '99 Guild JF-55N
'08 Stiletto Ace, 4 X 12 Recto Cab
PostPosted: Thu Sep 03, 2015 1:39 pm
To boost the crunch mode on my Deuce im using a Barber LTD or a Mesa Grid Slammer with wonderfull results.
or, if i want a more AC flavoured tone, i fire my Wampler Ace 30. 8)
Amps
Stiletto Deuce
Mark III simul blue stripe
Mark IVA
Blue Angel 2x10' combo
Cabs
Mesa Thiele EV
Mesa Open Back EV
Mesa Open Back VS 12 (2)
Guitars
Gibson Les Paul Custom 92'
Gibson Flying V 02'
Fender Am Std Strat 96'
PRS Singlecut 02'
PostPosted: Tue Oct 06, 2015 10:05 pm
I've been having nice results into CH 1 Crunch with a Catalinbread Naga Viper (treble booster) for some awesome late 70's hard rock/metal tones. Unleashed In The East, Victim of Changes just leaps out of the guitar, as well as Schenker, UFO lead tones. But for a more "transparent", the amp just got hotter/fatter effect, my M.I. Audio blues pro set to the fuzz setting with modest gain and level at just over halfway is amazing. Sounds better that Tight Gain or Fluid drive on CH 2 and I like both of those a lot. Also great into my Metro '69.
PostPosted: Wed Oct 07, 2015 1:27 am
Barber 1/2 Gainer... External mids knob is priceless!
Stiletto Ace Head
Rectoverb S2 Head
Mesa Traditional 4x12
Marshall G1265 cab
Widebody 3/4 back 1x12 C90
mini rec cab
PRS Mira
PostPosted: Wed Jan 27, 2016 5:51 pm
I think that it depends what you are looking to get out of it. I used a Boss Super Overdrive for years with my Ace combo and it just matched great. I never liked Tube Screamers with that amp.
Mark V Combo
EVH 5150 iii 2*12 Combo
1987 Marshall Lead 12 Combo
Les Paul Studio
Peavey Wolfgang Special
Fender EVH Wolfgang Special Hardtail
Fender EVH Wolfgang Special Stealth
1987 Kramer Pacer
American Deluxe Strat
http://www.rivermud.com
PostPosted: Mon May 09, 2016 1:44 pm
I can't say enough good things about the EHX Soul Food. Amazing pedal. Very transparent, versatile and powerful. I'm still in awe on how much it costs.
...Bleed Boogie forever...
Mesa TC50 Head
Mesa Stiletto Deuce II Head
Mesa Subway Rocket 1x10 Combo
4x12 Recto Slant Cab
2x12 Recto Compact Cab
PostPosted: Mon May 09, 2016 5:15 pm
I am with you on this one, the Tube Screamers have a mid bump and the last thing the stiletto series needs is a mid bump pedal.
Another good choice is the maxon 808, it is a nice clean boost and does not color the sound at all to my ears.
PostPosted: Sun Jun 19, 2016 6:16 pm
Fairfield Circuitry works well, anything that provides transparent clipping... tried a few and you do have to be mindful with this amp, transparent style OD's seem to pair well but I found anything with a low/mid low boost was mush ( TS9, Way Huge Red llama and even the Mesa Throttlebox were mushy)
Don't count out simply boosting in front with an EQ, but if its purely more clipping your after go for something more transparent with some headroom, the OCD running at 15-18V for example is tasty! An Echoplex Boost in the loop is fun too! :)
PostPosted: Mon Jul 11, 2016 9:21 am
DOD 250 (clone)
Keeley modded DS-1
TC MojoMojo
and like was stated above in another post, anything with too much emphasis on the low mid/low end will mush it up. Even the MojoMojo is on the verge of that but great for smooth single note lines. Also used a The Distillery pedal but could get it to mix with the amp, gave it away.
The DOD 250 clone I made sounded like the amp with the gain/volume bumped and just a tiny bit fuller. Like another channel of the amp I'd call 'Fat Crunch' Stayed on my main board for years. The modded DS-1 works great on the crunch channel but might be a bit much depending on the style music you play, works extremely well on the tight gain mode.
Isaac Berumen
Berumen Guitars
https://www.facebook.com/BerumenGuitars/
Users browsing this forum: Paulie and 1 guest
