Help me with this gut shot for my Deuce II
Ace, Version 1 and 2
skoora
Post by skoora » Fri Feb 27, 2015 10:25 pm
OK, so my Deuce (bought used) performed great for over a year and suddenly started a serious feedback howl when taken off standby. I thought maybe just a bad tube. I open it up for the first time since I bought it and found this on V1. Any ideas what is going on here. The (copper?) foil is soldered to a resistor on the board and connected with putty to the back of the V1 tube socket.
Gordybaby
Re: Help me with this gut shot for my Deuce II
Post by Gordybaby » Sat Feb 28, 2015 8:52 pm
I own a stiletto ace head that has the same thing. Its not a mod for sound but it fixed a factory defect on the circuit board that caused both channel masters to work together instead of separately. Apparently there are more than one with this problem.
skoora
Post by skoora » Sat Mar 21, 2015 5:28 pm
I eventually found out from Boogie it's just to shield a sensitive part of the circuit.
bandit2013
Triple Recto
Post by bandit2013 » Thu Nov 05, 2015 8:52 pm
I have seen something quite similar in both Mark V and Mark IV amps. Usually over a few film type capacitors.
Sometimes noise issues are fixed with goofy add-on's like this.
NealgeKeply
Post by NealgeKeply » Fri Sep 07, 2018 12:23 pm
I thank you both for your help. Ill chase the threads with a tap and start from there
By the way, I found used 2011 Hyundai Genesis 4. and if I hadn't found Vinchain http://vinchain.io/report/check car registry database service, I'd paid cash for vehicle with all over damage. Hope this helps someone, they are better than other vin number websites in my opinion.
