Fulltone OCD for Stiletto?
Ace, Version 1 and 2
guitarchris76
Post by guitarchris76 » Wed Apr 04, 2012 9:32 am
I am trying to decide between a Fulltone OCD or an Octafuzz for use with my Stiletto ACE combo. I only play at low bedroom volume so was thinking the OCD might give me that fullness you get when you crank an amp at low volumes. I love the sound of the Octafuzz but will only go for this if the OCD will not give me what I am looking for. Any thoughts?
dmain
Re: Fulltone OCD for Stiletto?
Post by dmain » Wed Apr 04, 2012 10:23 am
I use an OCD and it pairs very well the stiletto. It is a very versatile pedal capable of a lot of different sounds so i think it will do what you want. But hey if you love the octafuzz maybe thats what you will be the happiest with.
Hamer Special w/ P90's
Stiletto Ace 1x12 combo
Carvin V412 cab w/ Weber speakers
Fulltone Fat Boost v3 & Fulltone OCD v2
Boss DD-20 Giga Delay & Boss RT-20 Rotary Ensemble
EHX Holy Grail Reverb, POG2, & Stereo Memory Man
fdesalvo
Post by fdesalvo » Wed Apr 04, 2012 10:46 am
The Stiletto takes pedals very well in general. I'm using a Timmy V2 and a Musket Fuzz and she loves the sh!t out of those.
~F
Ruining good moments since 1975
1993 Ibanez S540LTD
2011 Stiletto II | Homebrew 5E7 3x10
http://www.soundcloud.com/frankdesalvo
shwing5150
Post by shwing5150 » Sun Aug 10, 2014 8:52 pm
I use the OCD as well, sounds great through this head, the above poster is correct, this amp loves pedals and the tube buffered FX loop sounds great too! did you know you could use the fl loop as a boost? well yes you can
Anyways, I have a older Rocktron Intellifex running in the loop for some plater reverb and a wee bit of slap delay I also turn off the HUSH), sounds beautiful :-)
This amp rocks because it loves pedals in the front and loves racks (or good pedals) in the rear effects loop...the manual has useful tips for using the loop
I have a Lee Jackson tube loop in my marshall and he has a short video clip explaining how to use his loop (which is also tube buffered - 12AX7, same as the Boogie), a lot of the information applies to the Stilettos fx loop, listen for when he says how Paul Gilbert used the loop as a boost
It's a small video of him showing how to properly use it, he used to stream it but I couldn't find a stream so this is right from his site:
http://www.leejackson.com/MasterSeries/ ... stall.html
Link to video:
http://www.leejackson.com/MasterSeries/ ... ovie_8.mov
Hope this helps some :-) I learned off it, it makes a huge difference once you learn how to properly use this kind of loop
Party on Wayne, Party on Garth
