Stiletto 2x12 impedance question.
giantstepjoe
Bristol, Ct.
Hey folks, I just added a stiletto 2x12 to the stable and I m loving it but I have one question. I can't seem to find out which of the speaker jacks the speaker load should be plugged into. 8 ohm or 4 ohm? I couldn't find the answer in the manual. Thanks!
It depend on 2 things: what is the ohm rating on the speakers and how are the two speakers wired (series vs. parallel). If you find this information, you can look at the Stiletto's ownner's manual and it shows a variety of wiring diagrams. You can figure it out from there.
Thanks for the reply. I should have thought to test it earlier, I forgot all about my meter! It tested 6.56-6.8 ohms. I would assume that is an 8 ohm load.
