Elbowselbows
- Joined
- Oct 8, 2012
- Messages
- 31
- Reaction score
- 0
So I guess I've had a bad rectifier tube in the 50 watt setting since I got the head. When set up to tube rec at 50 watt spongy there was volume problems and has gotten worse over time until now when I was able to hear crossover distortion and noticed the glass hasen't burned in the same as the other two rec tubes, the filament is a lot dimmer too.
I switch around the rec tubes and the problem stopped, maybe I can get a warranty on the rec tube.
