Ok, So I recently picked up a used Stage II and noticed the rec tubes and a few of the power tubes made a fair amount of mechanical noise when tapping. So I decided to give some JJ's a go as I've used them with success in the past with Marshall's I've had. Just using a basic bias probe I noticed with the Mesa tubes that the bias goes from anywhere between 39 to 12 depending on the amp settings. 39 when in CH 1 clean, bold and Silicone Diode and 12 when any gain mode, spongy, tube rec. For those who have done bias mod's what are you setting for your optimal. Because 39 is actually higher than I would usually set an El34, even with 450 on the plates (read this was spec for the Stiletto). But obviously 12 is ridiculous too. I guess if the JJ;'s fall into this same range I should just call it good and leave it be?
