OK Boys, Overdrive Pedals
Ace, Version 1 and 2
Riff Blister
Post by Riff Blister » Sun Mar 21, 2010 4:43 pm
What kind of OD pedals are you using with you Stilettos?
Have you found that magic stomp box that you really like?
Stiletto Deuce II, with bias mod - 2x12 Recto Cabt. Scumback M75s inside
Bogner Shiva EL34 80 watt
Budda Superdrive II 45
’79 Gibson Les Paul Custom Silverburst
’85 Gibson SG ’61 Reissue
Fender American Standard Stratocaster and Telecaster
cragginshred
Re: OK Boys, Overdrive Pedals
Post by cragginshred » Sun Mar 21, 2010 5:10 pm
Had the bb pre ala Timmons, however, it has been replaced by the Maxon OD 808. Running effects and the all important Eq through the loop, then the Maxon in to the front of the amp and it's top shelf distortion as a perfect layer over the Stiletto's excellent gain channels. The Maxon sold ibanez the 808 circuit in the early tube screamer models, and the newest has the 808 circuit. It is more evenly balanced than the overpriced BB pre, and it sound sweet rolling back the volume knob as well!
droptrd
Post by droptrd » Sun Mar 21, 2010 10:28 pm
This is my favorite topic about the stilettos. They are the most transparent and responsive amps ive ever played thru. every guitar, pup and stompbox you throw in front of one will dramtically change the tone. Awesome. Ive really started to build my OD collection when I got my stiletto. My 2 favs are the Barber Direct drive and the danelctro CTO-1. Ive also found you can get instant SRV with an OD808 on tite gain mode! The barber just kills though. Ihave catalinbread boxs, menatone, fromel and many others and for me the barber is untouchable
F50
Mesa and Randall Cabs
Lots of other sh!t too
cvansickle
Post by cvansickle » Mon Mar 22, 2010 6:59 am
My two favorites for the Stiletto are both from HBE: the Power Screamer and the Germania.
I keep the Screamer on low gain but high volume, so it's more of a clean kick. The Germania is set up about half way, and it gives gain with certain tone frequency changes. Mine has a three way switch for tone, so it can give boosted treble, more treble, or boosted low mids. Treble settings are good for Les Pauls, low mids for Strats.
Death Or Glory - Who Dares Wins!
surferdeac
Post by surferdeac » Mon Mar 22, 2010 11:08 am
I have only used the maxon od 808. Sounded Great in all the clean channel modes and could be tweaked to sound decent in the dirty channel of the amp. I cant believe nobody on this board has really given much attention to the Bk butler Tube driver pedal. So many great players have used this pedal in their rigs to achieve some killer tones (David GIlmour, Eric Johnson, Joe Satriani, Andy Timmons (used this pedal to recreate some of the tones from his resolution album in The STILETTO's clean channel ; the bb pre he uses mostly in the LONESTAR). I want to get a Bk Butler Tube Driver for my Stiletto eventually. So many people have raved about this pedal on other Boards. Just trying to get my nerve up to throw Down some Dough on one :mrgreen:
ACE HEAD
2x12 Rec CAB TC G Major 2
Maxon OD9 pro plus
VOX BIG BAD WAH
DMC Ground Control Pro
MORLEY HUM Eliminator
Ibanez Guitars JEM/RG/Classical
Pro-Tools Recording Setup
cragginshred
Post by cragginshred » Mon Mar 22, 2010 10:31 pm
The Maxon 808 is not just for SRV, it nails the electric gypsy tone with a little vol roll of at the guitar, also it adds sustain, OD and transparent girth to the stiletto's mojo for killer Petrucci solos too! As for the BK tube driver, I bought one and sent it back eating 75$ just to get him to take it back for $300. It sucks for any chording stuff, big note OD soling and subtle stuff it could work well with, but in general rolling back the volume from higher gain settings I can get everything I want with all kinds of subtle Gilmour bluesy stuff out of the stiletto and the Maxon.
mikey383
Post by mikey383 » Mon Mar 22, 2010 10:32 pm
I'm using a tubescreamer clone that I built. It sounds fantastic through my Stiletto. Unfortunately, I can't use it in my rig, since I switch from clean to distorted quite often.
I'm going to build something so I can use it though.
Guitars:Schecter C-1 Classic, Ibanez RG7321, Epiphone LP Supreme
Amps:70's Earth head
Cabs:Recto 4x12, 5150 4x12
Effects:Digitech GSP2101, Budwah
Past amps '95 Dual Recto, '96 Dual Recto, Stiletto Trident, 3 ch. Triple Rec
surferdeac
Post by surferdeac » Tue Mar 23, 2010 5:42 am
cragginshred wrote:The Maxon 808 is not just for SRV, it nails the electric gypsy tone with a little vol roll of at the guitar, also it adds sustain, OD and transparent girth to the stiletto's mojo for killer Petrucci solos too! As for the BK tube driver, I bought one and sent it back eating 75$ just to get him to take it back for $300. It sucks for any chording stuff, big note OD soling and subtle stuff it could work well with, but in general rolling back the volume from higher gain settings I can get everything I want with all kinds of subtle Gilmour bluesy stuff out of the stiletto and the Maxon.
Hello Cragginshred just wondering to be sure if when you were discussing the Bk tube driver you were referring to it with use with the "Stiletto" with regards to it not being the greatest with regards to chording stuff? I myself have heard from other people that the tube driver pedal sounds super great in some amps and not so super great in others. i have also heard that the 4 knob version he is currently making sound really good, and some people have gone so far to say that changing out the stock preamp tube it comes with can make a big difference in whether or not your gonna dig this Pedal.
Thanks
ACE HEAD
Maxon OD9 pro plus
VOX BIG BAD WAH
KH Guitar Freak
Post by KH Guitar Freak » Tue Mar 23, 2010 9:02 am
Well, I only use my Dunlop Hendrix Fuzz Face with my Stiletto. Ok, it's not an overdrive pedal, but what the hell...
Riff Blister
Post by Riff Blister » Tue Mar 23, 2010 12:30 pm
Thanks guys.
I've had a couple of Bixonic Expandora pedals on my board for a long time. Around ten years I think. Yikes!
I'm thinking maybe it's time to change thing up.
I've been eying the Xotic products or maybe that Barber Direct Drive that droptrd is lovin'.
The Tim or Timmy sound like they could be pretty cool too.
Lots of good choices.
Old BF Shred
Post by Old BF Shred » Tue Mar 23, 2010 1:10 pm
mikey383 wrote:I'm using a tubescreamer clone that I built. It sounds fantastic through my Stiletto. Unfortunately, I can't use it in my rig, since I switch from clean to distorted quite often.
Which one did you build? I am interested in doing the same, but there are too many choices!!! :lol: :lol:
Stiletto Ace head
Triaxis/50-50
4x12 and 1x12 cabs
Studio Cal 22+
Various Hamer, G&L, Jackson
"Old rockers never die; we just start to smell that way...or is it the amp?"
mikey383
Post by mikey383 » Tue Mar 23, 2010 1:40 pm
Mine's a TS808 clone.
They're not very hard to build. I used a Radio Shack project board and point-to-point wired everything.
cragginshred
Post by cragginshred » Tue Mar 23, 2010 8:30 pm
Surferdeac,
I used it with the stiletto's clean channel per Timmon's recommendation and video reviews. It was ok, but not worth the $ at all. It was a brand new one from BK himself just 2 months back. As I said you could certainly use it many ways but nothing that was as cool as what I am getting with the gain modes in the stiletto.
Vigo1999
Post by Vigo1999 » Thu Mar 25, 2010 1:47 pm
my vote goes for a Barber DD. although it's a TS based OD it can be set to avoid that typical "middle honk".
just lke this: :)
http://www.youtube.com/watch?v=rBAKySMusog
Amps
Stiletto Deuce
Mark III simul blue stripe
Mark IVA
Blue Angel 2x10' combo
Cabs
Mesa Thiele EV
Mesa Open Back EV
Mesa Open Back VS 12 (2)
Guitars
Gibson Les Paul Custom 92'
Gibson Flying V 02'
Fender Am Std Strat 96'
PRS Singlecut 02'
cragginshred
Post by cragginshred » Thu Mar 25, 2010 10:54 pm
Viggo,.... nice shredding! I dig strats that go from mellow bluesy gain stuff to full on melt your face shred! Were you using the Stiletto's clean channel with the barber, or one of it's gain setting plus the barber or a different amp or what???? The bummer about the barber video reviews just like the maxon reviews is, it gives you no idea of what it is like going in to the front of your amp boosting you rigs current gain settings. Thanks for you vid and please provide more info regarding amp used and clean or amp gain settings.
