cragginshred wrote:
What are the thoughts out there regarding digital delays adding to the potential harsh tones that can occur with the stiletto's particular voicing? I have had the Keely moded DD3 (sold it) as well as currently running the TC nova system, which I dig, however, turning off the delay and verb it immediately warmed up my signal. So, I bought a memory man today and will see how that fairs once it gets here. The interesting thing is in certain settings the TC works well using a digital dual delay setting- with my Music man JP axe and my Carvin V3 - great blend, however, with the strats (AT Dimarzio hum in bridge, cruiser in the neck) in to the Stiletto with the TC digital effects,... well this combination does not blend as well,.. thus I am led to believe the memory man deluxe will jive better with the stiletto and strats mojo.
Most digital delays won't ADD harshness (unless they're of low quality), but if your amp is harsh sounding, you'll hear it more. Analog delay rolls off highs with the repeats. With a Strat and a Stiletto, you may find that this is more desirable than hearing uncolored repeats.
