90s Maverick?
DrewATL
Hello all-
I’m the proud owner of what appears to be a never-gigged Maverick 4x10 as it was owned by a local amp builder and utilized as a bench amp, and what appears to be a pigtail connector for accessing its speakers only.
The second owner had it re-tubed recently and I picked it up for $650.00 cash.
My questions are, is there anyway to date this amp, any cool/special features that aren’t listed in the manual (PDF) and I managed to get a small dimple in the grill cloth, nothing major but I was hoping a spritz of water and blow dryer might sort that out as it is absolutely mint.
https://imgur.com/a/4qqVvyq
DrewATL said:
*bump*
Also the reverb doesn’t work, do I need a pedal to switch it on,
The reverb should just work. I would check the connections to the tank, and the reverb driver tube. It also does have a footswitch that can defeat the reverb, so make sure that is clean.
