Mesa Rectifier Badlander
user 83592
Just noticed this ad:
https://imgur.com/a/2QhfPro
here's the whole page:
https://imgur.com/a/20td7Jv
The ad goes to mesaboogie.com, but there's no product announcement.
Looks cool though! Anyone know anything?
Ola makes everything sound good, but that sounds real good. Especially liked the active pickup demo. Updating the gain structure a little is definitely not a bad idea, Rectos don't have quite enough usable gain for some modern styles (whether you like those styles or not isn't the question lol.)
This thing looks to be a monster. I'd love to hear the Badlander mixed with a MWDR, I think that would crush! I also love the reduction in the size of the amp. Now it looks like it will fit on top of the Vertical 2x12 cab.
Man Ola is a chugger. Lol. There was another video from some music store in wisconsin which really gives a great impression of the amp.
https://m.youtube.com/watch?v=gcHABCIEqaA
I’m not affiliated with them in any way, but it is a decent overview
No Boost or FX on the foot switch. What’s up with that ? Looks like a nice amp except for the one button foot switch. Mesa should re-evaluate that
I am really surprised at the negative response due to the single foot switch versus multiple switch pedals.
I've never had a big Recto, but I've had the V-Twin(similar to channel switching on a Recto, I presume) and the single switches for the ROV25.
I guess I don't really have a preference for either but I guess if you're gigging and don't want to run a long trunk of cables from the front of the stage to the back, I guess its a PITA.
I got my 100W Badlander in last week. I really like the amp allot, Ive owned plenty of Mesa Boogies over the years. I ended keeping 6L6 in the amp and I really like the tight low end, no more flub. The Badlander sits between the V and the old recto's. Great amp !!!!!
I got mine last day in November.
Nice amp. I did compare this to the Multi-watt Dual Rec. Very similar but different. Sub-harmonic content has been reduced considerably. Still has plenty of low end to get the job done. I would not have noticed this if it was not for the Badlander. When I compared the MWDR to the Roadster, thought they fixed the low end drone. Also tried running 6L6 tubes (SRT440 grey which is the same color code in my MWDR), thought they sounded lame when comparing to the MW with the same tubes. EL34 perform much better in the Badlander. Just my opinion. Running both amps (Badlander and Multi-watt Dual Rec) is amazing. This new amp has not taken away any desires to run the Multi-watt Dual Rec or even the Roadster. It is different but with some similarities. I find the crunch voice on the Bad to sound similar to the Modern voices on the other two. Some have compared it to the vintage voice. Crush is one step further into compression, which is lacking in the other Rectifier amps. Midrange content is there in a musical way. The other two have more of a scooped tone. Also tried the variac power mode which does bring the Bad closer to that of the Multi-watt on the bold power setting. Most important, the tone stack is also different. Bass, Midrange and Treble actually do something, they do not appear to be dependent on one another. Presence control is also more reactive. Yes, the Badlander will fit onto the vertical 212 cab. Shell is basically the same as the TC series but without the reverb tank. That is about all of what is similar to the Triple Crown except for Mesa tubes installed. Transformers are different, not the same numbers as found in the MW or TC. Comparing the Bad to the TC, there is non. TC sound thin in comparison and that is with the TC red channel vs crunch or crush on the bad. Feedback and harmonic characteristics is very similar to the JP-2C but darker in some characteristics. I have run the JP-2C in tandem with a Marshall Silver Jubilee JCM2555x reissue, now that was something I thought would be unique. Not anymore as that is what I feel the Badlander sounds like in crush voice. JP-2C + TC-100 would be a similar comparison to the Badlander (for those who get offended when a different brand of amp is mentioned). Have not found any issues with the FX loop either. I have not tried any instrument level pedals though, I tossed all of that gear after I got the Mark V 90w as it was not compatible. I now use Strymon stuff in my loops, in addition to two or three boss pedals (Boss DD-200, Boss EQ-200, Terra echo TE2, Strymon: BigSky, BlueSky, Brigadier, DIG, Volante). I still have a tone sucking delay pedal (Line6 DL4) that does not work in the Mark V but does ok with the TC and JP-2C. I should pull that out of its little coffin and see it if it sucks or performs well as it is an instrument level pedal based on what specifications I could find. Interesting amp, something new but familiar. Not very hard to dial in, no decoder ring needed. I personally would get the 100w model. Bigger iron goes a long way even with the 50W and 20W power modes. That 20W power is no lame duck either. The 50W is almost the same as the 100W with one exception, there is more saturation at the 100W power than at 50W. Will need to explore this more at gig levels. I have not been pushing my hearing threshold lately. Don't expect the Badlander to be a duplicate of the Rectifier amps, it is not, similar yes, identical no. If there was such a scale to gauge where the Badlander sits in the tone farm, based on the amps I have, the Roadster would be to the far left (in terms of darkness and sub harmonic content). Mutli-watt would be next but not at the same location. Badlander, then JP-2C, TC then Mark V. I put the MarkV90 in its location due to its ice pick issues and upper midrange peak in tone. This may be exaggerated to some extent.
Bass amp------------RDSTR------MWDR-----BAD----------------JP-2C---------RA100-----TC100---TC50----------------------MKV90----------Crash Cymbals
What about the Badlander didn't trip your trigger?
Edit: Nevermind! Saw you other link to the triple rec mods you are peddling. Makes sense now!
Although, would love to see (hear) a direct comparison of the Badlander to the modded Triple Rec!
CoG said:
ADVGANG said:
sold it the day i got it. not for me.
Pretty close to "pics or it didn't happen", man. Specifics?
He posted a video of his Badlander:
https://youtu.be/dRD7A6dskGM
Then a modded TR 3 chan solo head
https://youtu.be/-cWyuTlFvs4
And then one-upped himself with a DR 2 chan Rev E in mint condition.
https://youtu.be/6eQrR059jpk
The Rev E still has the tag on it for goodness sake. I believe him :lol:
it's the user manual!
Thank you for this comparison, I have been looking for comments from someone who has tried the range of Mesas. Have to agree on where the Mark V sits on your scale. I had been eyeing a Badlander, but none of the You Tube demos made me want to run out and buy one. Just a few days ago I tried a Cab Clone IR and instantly returned it, sounded very processed to me, so that feature of the Badlander is basically useless. I also had a Triple Rec and Roadster years ago, and I probably will go for a modern Dual Rec here in the coming months.
