sean106ESP
Hey everyone, long time no post.
I just picked up a 50th Anniversary Dual Rectifier. I normally play a Diezel VH4 but was missing those old tones I loved back in the day and wow does this amp have it.
I am having issues with the FX loop, Loop Level knob and also output knob. The manual really does not explain it well in terms of how they all work with each other and I have been fiddling around with it all night. (Or maybe I am just too dumb to understand it lol)
So when I am on say.....channel 3 modern and I have my main rhythm metal tone dialed in.... when I engage the FX loop with the foot switch... the tone changes immediately (and not for the good. Lowers the volume as well even if the FX loop knob on the back is set to 12 noon).
Also another thing I totally CANNOT wrap my head around is this...
So I have a TC Electronic Flashback Delay and MXR Chorus. On my VH4 I stick the chorus in the channel insert of channel one for cleans. Then in the parallel loop of the VH4 I stick the Delay for my clean and lead channel for solos. I use the FX loop level on the front of the VH4 to blend it in while the delay is at 100% wet.
On this new dual Rectifier when I turn on the FX loop with the delay ON...
1 I get the tonal change
2 I get this bizzare backward delay of notes being produced. Like I pluck a few notes and then they play a second or two later out of sync and delayed but sound horrible.
So in a nutshell.... Any advice on how the FX loop works and what are the best practices?
My last amp before the Recto was a Mesa Mark V. Which I think I had the same type of FX loop. I stuck a delay in the loop, left the loop on at all times and simply turned on the delay pedal when I wanted delay and zero issues.
Thanks so much in advance!
