TNTRoy
Was letting the warm up while hooking up my guitar and pedal board and as soon as I flipped the standby switch to on the entire amp went dead.. No lights no sound or nothing.... checked fuse (with ohm meter) fuse is good checked all connections even removed the amp from cab don’t find any capacitors blown or no bad connections I can see... How do you check a power transformer? Which transformer is the main power??
