Roadster Reverb Issue
dwman3
Post by dwman3 » Tue Apr 30, 2019 7:13 pm
So the reverb is dead on my Roadster Combo but here's the kicker, when i turn up the reverb knobs on the back i get an increase in volume and gain almost like if you turned up the gain on a OD pedal but no reverb. Im thinking the reverb tank is dead and signal is getting passed through the reverb knob and that's why I'm hearing more of the weird volume and OD like gain increase. Ive tried 3 or 4 different tubes in the reverb slot so I'm positive its not a tube issue, the other thing is maybe i didnt put the little RCA connectors from the reverb tank in the right slot I'm looking at amp from the back which one goes first white or black? What do y'all think could be the problem or have any of you had a problem like this?
domct203
Re: Roadster Reverb Issue
Post by domct203 » Wed May 01, 2019 11:12 am
.......... the other thing is maybe i didnt put the little RCA connectors from the reverb tank in the right slot.........
Did your reverb work just fine before you disconnected it?
You should at least try swapping the connections, nothing to lose.
Authorized Boogie
Post by Authorized Boogie » Wed May 01, 2019 11:17 am
Sounds like you've got the reverb cables connected in reverse
dwman3
Post by dwman3 » Wed May 01, 2019 9:50 pm
Yup cables were backwards reverb works now. Now a new problem came up, a loud ass pop when switching to channel 3. I hope i didnt knock something out of place when taking the chassis out switch the reverb cables. Any one have popping problem when switching channels?
domct203
Post by domct203 » Thu May 02, 2019 5:03 pm
I’m guessing this is a new to you amp? Your first Recto?
Popping during channel switching at low volumes is a common complaint. With my Roadster, if I cycle thru all the channels a couple of times, ending on ch 3 just before I come out of standby, I never get pops at band volume, once an a while I’ll get a pop on the very first switch to ch 3, but that’s rare.
dwman3
Post by dwman3 » Thu May 02, 2019 8:30 pm
Yup new to me but not my first Boogie,I only ask cause it was the first time I heard an insanely loud pop when switching to channel 3.
bandit2013
Triple Recto
Post by bandit2013 » Sat May 04, 2019 7:14 am
I have tried the channel switching while in standby. Perhaps I am not doing it enough times. I generally cycle the channels as well as the mute after I take it out of standby following a cold start. After that I do not get pops. Good to hear you resolved your reverb issue. The white wire does not have a ground connection but the black wire does. Depending on the amp, you may get an undesired squeal if the wires are reversed. Enjoy the amp.
dwman3
Post by dwman3 » Sat May 04, 2019 10:30 pm
Thanks everyone for your input!!
