Tremoverb aluminum tube shield/bar
Ua the Destroyer
Anyone able to hook me up with the dimensions on this part? I’m talking about the aluminum U-channel at the back that guards the tubes.
I know it needs to be 26” long and I recall it being around 1/8” thick but I don’t know the width or the height of the legs on the U.
Thanks in advance.
Width----1 1/2"(1.5")
Leg height including the bar thickness of 1/8"(0.125")----1/2"(0.5")
Leg height without the bar thickness meaning just the inside height of the U----3/8"(0.375")
The dimensions taken from my stiletto head.
You can probably get the right U-channel off of amazon.
I do NOT know why people always seem to take these off the amp, and not put them back. I needed to get one for my DC-5 as well. You can get them from Mesa usually.
Thanks so much. My guess would have been right.
Yeah I could get one from Mesa but they quoted me over $100 for it. For a piece of common aluminum with 2 holes in it, seems high even for MESA. Especially considering many other parts on it are quite reasonable.
I’ve had it for a dozen years but it was missing it as far as I remember when I traded for it. I know the tremoverb combo I traded it for had one.
Additional info
Bar----24" long
Screw holes----0.16" in Dia located 3/8" from the edges.
Screw Size----0.16" in Dia & 0.55" long
thabks I ordered up some channel stock. The Tremoverb head must be wider because mine is for sure 26”.
